salty, dirty, cloudy, nasty glass
Old Mar 4, 2007 | 10:07 PM
uncle2abc's Avatar
uncle2abc
I am pretty sure one of the window washer squirters on my 97 ranger is clogged. The one for the passenger side works fine, but the drivers side doesn't.
How do you take it out/apart to clean it, and make sure the tube is still hooked up? I looked in my Haynes book, but it wasn't mentioned. I'm tired of having to pull into a gas station on the way to and from work to clean my windshield. I can't wait until winter is over and they stop salting the roads.
Old Mar 4, 2007 | 10:26 PM
RangerPilot's Avatar
RangerPilot
The ones on my '94 are visible from under the hood at the very back. In your '97, they may be the same, or they may be inside the cowl with a small access panel covering them. They pop out, and can be cleaned with compressed air, high pressure water, etc.
Old Mar 5, 2007 | 02:04 PM
ford_racing_4_life's Avatar
ford_racing_4_life
Like RangerPilot said, compressed air works good for blowing the lines out, just dont over-do it. the line runs underneath the reservoir from the motor and there is a break in the line where you can split it in two, thats the easiest place to blow it out from and should clean the lines out real good.
Old Mar 5, 2007 | 02:05 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Soak them in white vinegar.
Old Mar 5, 2007 | 02:09 PM
tomtoc's Avatar
tomtoc
i use hydrogen peroxide for everything like that. leave it in there and let it soak. ~$1 for a huge bottle of it. i'm guessing white vinegar is similar
Old Mar 12, 2007 | 08:57 PM
uncle2abc's Avatar
uncle2abc
I want to thank everyone who responded to this. I removed the sprayer soaked in a little hydrogen peroxide (spelling?) and blew it out. Works perfect. It worked so well I noticed the passenger side wasn't spraying correctly, so I cleaned it out too.
Old Mar 12, 2007 | 10:10 PM
fflintstone's Avatar
fflintstone
ya gatta love it. You'll probably be disappointed with how much washer fluid your going through now.!!
SasquatchZilla
Jan 1, 2012 09:14 PM
frederic
Garage & Workshop
May 28, 2007 01:57 AM
christaylor
1997 - 2003 F150
Jul 16, 2005 07:32 AM
kidzstang
1997 - 2003 F150
May 20, 2004 09:01 PM
matt f350
Jan 30, 2003 04:18 PM
