1978 - 1996 Big Bronco
Horn doesn't work on '94 Bronco
Old Aug 20, 2002 | 11:05 PM
miked2002's Avatar
miked2002
checked the fuses-all are working, yet horn doesn't work. won't pass inspection. any ideas?
Old Aug 21, 2002 | 10:28 AM
Kemicalburns's Avatar
Kemicalburns
my 88 is the same way. I found if i pushed the horn and moved the steering colum up and down it would work. the contact inside the colum might be all gunt up. but thats were i would look, not sure how hard it would be to take apart. good luck
Old Aug 28, 2002 | 04:08 PM
1stBronco's Avatar
1stBronco
Old Aug 28, 2002 | 05:35 PM
saanders's Avatar
saanders
From Ford's 1990 Bronco/F150-F350/F-Super Duty Electrical & Vacuum Trouble-Shooting Manual:
1. Check fuse.
2. Remove fuse and connect meter across fuse contacts. If meter reads battery voltage when horn switch is pushed, switch is good.
3. Attach a jumper between the battery and horn connector and another jumper between the horn bracket and ground (do this step for both right and left horns). If horn doesn't sound, turn adjusting screw 1/4 to 3/8 turn, then secure. If horn does not sound, replace horn.
4. Ground horn relay 1 (DB) wire. If horn doesn't sound, check relay (it's behind the instrument panel near the hazard flasher).
If you don't have one of these manuals for your truck, I strongly recommend getting one. You can usually find them on eBay (that's where I got mine).
Old Aug 30, 2002 | 10:49 PM
mckeeverm's Avatar
mckeeverm
If the horn doesn't work AND the airbag light flashes a 3 - 2 sequence AND the cruise controls don't work, then the problem is probably the "clock spring". That's the connector in the steering column that allows you to have buttons on the steering wheel and still turn the wheel!
If that is the problem, it's about a $100 part or a $300 repair at the dealer.
Mike
Old Aug 30, 2002 | 10:57 PM
Mil1ion's Avatar
Mil1ion
If you guys have Cruise control, the horn wiring gets switched around through the Turn-signal harness.
There should be a Horn relay behind the instrument cluster.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
pmh
18
Jan 26, 2021 09:55 PM
PhilcoPGM
Dec 7, 2010 07:44 PM
Dirt1dobber
Sep 23, 2006 03:12 PM
oskie
Jan 27, 2006 12:38 AM
jammin jim
Sep 3, 2004 08:44 PM
