Removing dash pad
Old Feb 6, 2007 | 09:42 PM
Bill W's Avatar
Bill W
Question Removing dash pad
Is this right? the dash pad is glued on, and stainless trim you can remove by squeazing the back part, sorry push pin., ? the front window is still in, Will that make it hard to get the pad off, If the pad comes off in one piece can it be covered to look stock The dash pad i have is radio delite is that rare? From the time i found this forum my 66 f100 has started to come apart for resto. I will be removing the cab as soon as i get the interior out Thanks for any help Bill W
Old Feb 6, 2007 | 10:11 PM
airharley's Avatar
airharley
From what I know the pads are glued on using strips of glue and not the whole surface. Use a long flexible piece of plastic and windex to run across the length of it a little at a time to keep from destroying. The windex will act as a lubricant but wont stain or soak into it. The less you force it around the better.
Old Feb 6, 2007 | 11:48 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The clips resemble a scissors. Squeeze them together.....then push em out. Take care removing the padded dash. they're tough to find.
I suggest you remove the battery cable. That small piece of trim on the left side means wiggling your hand around...above the ignition switch.
Old Feb 7, 2007 | 01:13 AM
airharley's Avatar
airharley
So much for the one experiance I had with a dashpad. That also explains why there were a bunch of little holes in the dash itself. For the life of me, the other guy and I couldn't understand why it had them. I will add this bit of info to my brain for future use. Thanks Bill.
Old Feb 14, 2007 | 11:06 AM
customcab66's Avatar
customcab66
I just gently pulled my stainless off and then peeled the pad off and then covered the dash with another peice of material.
papyjack
1978 - 1996 Big Bronco
15
Mar 15, 2016 11:02 AM
papyjack
Feb 28, 2016 06:02 PM
mustanginca
1983 - 2012 Ranger & B-Series
May 17, 2007 11:14 AM
Ol' Blu
Georgia Chapter
Dec 11, 2005 09:25 PM
fordv840
Feb 3, 2005 10:38 PM
