A freind (that is a mechanic) is helping me on my fuel line setup. Seems that when he trys to bender the line to go up above the manifold it gets a kink in it. He soes have a good quality bender and I believe the howe is 3/8" steel. He says it is because it such a tight bend and is thinking of running the line on top of the valve cover. Any suggestions would be helpful. I just don't like the way it looks running on top of the valve cover.
I would question the quality of the bending tool or the operator of the tool if it is a good quality bender like an Imperial or Rigid. It needs to be the "pliers" type that is specific to the size tubing you are bending, not a multi-size bender.
I agree on the quality of the bender (tool and person). Why not use aluminum line? You can bend that stuff with your fingers. You can certainly get a nice smooth bend with a decent tool.
Others have told me it could be the quality of the bender. I talked to our auto instructor and he said never to use the one that you rate as the worst. He has been using one you rate better. I haven't seen the one rated best before. I have seen some with a lever type handle but both were very cheap cost wise and I figure they were no good. Maybe our air conditioning tech has one that works better. Thanks. For whatever reason the aout instructor didn't like aluminum and I have been told told you'll never bend stainless steel. One gu suggested put grease on the bender track. Wlho sells the best one?
