Fuel line problem
Old Jan 13, 2007 | 09:26 PM
Delzell's Avatar
Delzell
Fuel line problem
A freind (that is a mechanic) is helping me on my fuel line setup. Seems that when he trys to bender the line to go up above the manifold it gets a kink in it. He soes have a good quality bender and I believe the howe is 3/8" steel. He says it is because it such a tight bend and is thinking of running the line on top of the valve cover. Any suggestions would be helpful. I just don't like the way it looks running on top of the valve cover.
Old Jan 13, 2007 | 10:00 PM
galaxie641's Avatar
galaxie641
What degree of a bend are we talking about?
Old Jan 14, 2007 | 09:47 AM
Delzell's Avatar
Delzell
I would say about 45 degree. Do you think steel is the best to use? We thought maybe it is just a lowsy grade that that Nappa sold us.
Old Jan 14, 2007 | 11:10 AM
LEckart's Avatar
LEckart
I would question the quality of the bending tool or the operator of the tool if it is a good quality bender like an Imperial or Rigid. It needs to be the "pliers" type that is specific to the size tubing you are bending, not a multi-size bender.
Old Jan 14, 2007 | 11:34 AM
Randy Jack's Avatar
Randy Jack
I agree on the quality of the bender (tool and person). Why not use aluminum line? You can bend that stuff with your fingers. You can certainly get a nice smooth bend with a decent tool.
Old Jan 14, 2007 | 11:37 AM
jniolon's Avatar
jniolon
old and in the way
Delzell
I can't imagine that 3/8" steel tubing should be giving you problems IF you're using a decent bender... good info above about a 'mandrell' type bender
these are your major choices... as rated by a rookie bender operator like me
and here's a bend with the one rated 'best'... about a 1-1/4" radius
I'd look at the bender... either the one holding it or the one being held
later
john
Old Jan 14, 2007 | 01:07 PM
ksmith203's Avatar
ksmith203
What is the name of the best bender? I am going to start my brake lines next week after engine install.
Thanks Kevin
Old Jan 14, 2007 | 01:43 PM
Delzell's Avatar
Delzell
Others have told me it could be the quality of the bender. I talked to our auto instructor and he said never to use the one that you rate as the worst. He has been using one you rate better. I haven't seen the one rated best before. I have seen some with a lever type handle but both were very cheap cost wise and I figure they were no good. Maybe our air conditioning tech has one that works better. Thanks. For whatever reason the aout instructor didn't like aluminum and I have been told told you'll never bend stainless steel. One gu suggested put grease on the bender track. Wlho sells the best one?
Old Jan 14, 2007 | 04:41 PM
jniolon's Avatar
jniolon
old and in the way
you should be looking for cam type tubing benders or lever type tube benders...
www.eastwood.com with a search on tube benders
www.toolsource.com
www.uniweld.com
www.grainger.com
but they aren't cheap... a 3/8" unit at Grainger is about 60 bucks
I don't know about grease... but I do oil the cam follower on mine... especially on tight bends... keep it out of the inside of the tube though.
john
"Top Fuel" Bender
26
May 3, 2013 08:41 PM
jjurva!
Jan 16, 2013 11:22 PM
GeneStoner
Garage & Workshop
May 4, 2005 07:55 PM
AKFord
Garage & Workshop
May 5, 2003 04:27 PM
