Climate control in kahoots with the GEM???
Old Nov 3, 2006 | 08:32 AM
Oil-Pig's Avatar
Oil-Pig
I just about have everything working the way its supposed to with the exception of a few things that I think may be connected to the same problem. The problems that remain are:
1. The Keyless entery system "will not stay active" <----The best way to put it What I mean is in order to use the keyfobs you first have to push one of the buttons on the door to kind of "wake up" the system. Then the remotes will work at this point I might as well use the key since I am already there. The keypad on the door works but only with the factory preset code. (The dealership had to data log my truck to find the code. The code that was listed where it was supposed to be was 9-11-9-11-9 and since there is no 11 on the keypad the tech said that something was corrupt but he could find the code by datalogging and the code he retrieved works)
2. My climate control will never blow out of the dash vents. But I can switch between the floor and the Defrost. I have checked the connection behind the glove box and both are good. If I hook a vac gage on the line coming out of the firewall I get 15 inches I have manually pumped it to 20 with no change.
3. I am having issues getting my hubs to Autolock. I have changed all seals and o-rings in the front thinking that I had a leak but no luck. If I turn 4x4 on and off sometimes I will end up with one hub locked and not the other even when off. I actually think its locking the hub when I am turning it off.
I can live with 3 and possibly 2 but I want my keyfobs to work without having to touch the truck first. With all my reading I have narrowed my solution to 1 to either a bad door keypad or a bad GEM. I don't want to start changing out parts for nothing so I am putting this up to see if anyone else had these problems or has any test procedures I can perform. Like testing the keypad?
Does the GEM have any control over the Climate system or the ESOF? What I am getting at is if I had something wrong with my GEM could it affect all these things?
Thanks in advance for your help.
Old Nov 3, 2006 | 10:07 AM
Pickupmanx2's Avatar
Pickupmanx2
Just going by the symptoms you have described, I would say you have a vacuum leak somewhere in your system, that will affect the ESOF, and your controls. Have you put new batteries in your fob,,, but, I would still go with a LARGE vacuum leak, because that sends the signal to everything for what it is supposed to do, or a small leak in conjunction with the GEM acting up....
Old Nov 3, 2006 | 10:34 AM
Oil-Pig's Avatar
Oil-Pig
Thanks for the reply.
My vacume holds at 15 inches and my vac pump hardley runs? If my truck sits for a while or I switch the climate comtrol systems around my pump will kick in run for about a minute and shut off when it gets back to 15 inches. If I had a leak the pump would constantly try to keep up wouldn't it? Plus I would see a constant loss on the gauge.
Old Nov 3, 2006 | 01:08 PM
Oil-Pig's Avatar
Oil-Pig
Does the GEM control the vac pulses for the ESOF?
Spades
Sep 26, 2019 04:33 PM
osheam
Sep 14, 2015 07:41 PM
pw1981
Apr 4, 2011 06:49 PM
Baze
Mar 30, 2004 07:53 PM
jcb67
Jun 24, 2002 05:34 PM
