Wire For Transmission sender/Sensor to Ignition
![Exclamation](images/icons/icon4.gif)
Looking to find the ignition wire for transmission Temperature guage I installed...One wire goes to the ignition wire but im not sure the color of it??? 2000 ford ..7.3..anyone familiar with it?
You mean a keyed hot?
2000 Ford F Series Security Information
Constant 12V+ Green/Purple or Yellow Ignition Switch Harness
Starter Red/Light Blue Ignition Switch Harness
Ignition Red/Black or Blue/Green Ignition Switch Harness
Ignition 2 Gray/Yellow Ignition Switch Harness
Ignition 3 Dark Red/Black Ignition Switch Harness
Accessory Gray/Yellow or Blue/White Ignition Switch Harness
Tach White/Pink BCM, Pin 48 of 104 Pin Connector or Pin19 if Diesel
Neutral Safety Wire Red/Light Blue Ignition Switch
Brake Switch Red Brake Switch
Trunk Pin n/a
Parking Lights Brown (+) Driver's Kick Panel or Light Switch
Head Lamp Red/Yellow (+) Light Switch
Factory Disarm Dark Green/Purple(-) Driver's Kick Panel
Door Trigger Black/Blue (+) 40 Pin Connector Firewall behind Driver's Dash
Door Lock Pink/Yellow High Driver's Dash Negative Trigger w/Keyless Entry
Door Unlock Pink/Light Green Reverse Polarity w/o Keyless Entry
Driver's Lock Pink/Black Driver's Door Boot
Driver's Unlock Red/Orange Driver's Door Boot
Passenger Unlock Pink/Orange Keyless Module
Horn Wire Dark Blue (-) Brown 6 Pin Connector behind Driver's Dash
Windows Up LF=White/Black, RF=White/Yellow, LR=Gray/Orange, RR=Yellow/Black
Windows Down LF=Orange/White, RF=Tan/Light Blue, LR=Yellow/Light Blue, RR=Red/Blue
Trunk Pin n/a
Reelman1a1
20
07-28-2006 05:46 PM
MudBugn
03-30-2006 11:35 AM
