unknown wire
Old Sep 10, 2006 | 06:55 PM
16diesel's Avatar
16diesel
Question unknown wire
<HR style="COLOR: #666666" SIZE=1>
i was changing the oil on my 1990 [font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif][font=verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif]ranger[/font][/font] 2.3 5spd to day. when i pulled my oil filter wrench off of the filter to take it out from the bottom a single wire with a connector fell down. the wire is red with a white mabye oragne stripe. the covering that it Ts off of continues on and conects to the back of the transmission with 2 wires. all my gauges work and the truck starts and has no error lights (however i didnt drive it long enough to see if the temp gauge worked) i felt all over the block and and looked all around the drivers side of the engine but coulndnt find a missing conection. is this just a extra wire? or somthing else?
Old Sep 10, 2006 | 09:49 PM
Franklin2's Avatar
Franklin2
Red wire with a white stripe is usually the water temperature sending unit wire.
White wire with a red stripe is usually the oil pressure sending unit wire.
gcreamer
1997 - 2003 F150
13
Dec 22, 2006 06:24 PM
CMW
Bronco II
Oct 10, 2006 12:46 PM
cb88
Bronco II
Sep 22, 2006 01:59 PM
Scoop531
Jul 10, 2006 02:32 PM
BodegaErik
Jul 3, 2006 05:19 AM
