Help with F-350 1990 460 location of fuel pump connector
Hi
I own a 1990 F-350
I have been working on this truck for at least 3 weekends in a row. this truck once ran for about 5 minutes then quit runing. I dont understand. So I performed a fuel pressure test and came up with 5psi. I know thats way below specs so i decided since i have new parts around the shop i would install them. I installed a new fuel pump relay switch and a new fuel pressure regulator and still the fuel pressure is at 5 psi. Would anyone please help me out with the problem because i do not understand now where to go and both of the fuel pumps are fine they both work properly also I have installed a new fuel filter aswell any ideas please help me thanks Jaeger also I now notice that when resaerching on all data I learned maybe pin connector number 6 from the fuel pump relay and PCM nay not be grounding where do I look to find the location of that wire and color please help me I need thius truck out of my shop Thanks and hoping to hear back Jaeger
I own a 1990 F-350
Originally Posted by MudBugn
Hi
I own a 1990 F-350
I own a 1990 F-350
Had a garage look at it for two days and they couldn't figure it out. I only figured it out after I replaced the fuel pump, saw it was fixed and then took apart the old pump to see what was wrong.
Moral of the story: you never know if the pump is really OK.
Good luck
DUALLYNOTED
Computer Chips & Tuners
09-25-2006 05:08 PM
Mikes67F250
05-30-2006 03:09 PM
