how many cfm a speed density system flows on a 92 351? This is the third forum I have asked in and I always get ignored so can someone please give me some insight here?
503 CFM at 5500 RPM and 90% VE. 447 CFM at 80% VE. You could get to 800 CFM but I'm guessing you'd have to spin it to about 8-9000 RPM. I think the piston speeds even at 5500 would be pretty high.
Wow thats deep....this is way different than carbs evidently.....usually I would rate my carb at 600cfm......am I asking the wrong question or is that just the way EFI is? Should I be asking.....what does a 56mm T-Body flow?
There is no direct comparison for a carb CFM rating and an EFI system. For a carb, the carb is the restriction. The rating follows an SAE set of assumptions/guidelines. And at normal atmospheric pressure, non-turbo or supercharger, it flows a max = the carb cating, 600CFM for example. That's all it means. Doesn't mean it flows that actually on a car - that all depends on displacement and RPM - as mentioned. For actually engine CFM, the previous descriptin is accurate. But trying to compare a carb to EFI for performance or efficience, I guess was the driver for this question, is to compare apples to oranges.
Carb cfm is rated by flow at a fixed vacuum level below the carb, a throttle body can be measured the same way. This is not the same as the cfm required by the engine, it just provides a standard for measuring airflow.
