351M or 351C
Old Jan 24, 2006 | 04:32 PM
warecreek's Avatar
warecreek
351M or 351C
How do I differentiate a 351M and a 351C easily?
Old Jan 24, 2006 | 06:39 PM
6t6merc's Avatar
6t6merc
Usually - the 351C cylinder head has a 2 or 4 cast in its outer corner next to the valve cover, the 351 is blank - usually.
Old Jan 24, 2006 | 06:43 PM
m in sask's Avatar
m in sask
The bolts holding the fuel pump on a 351 cleveland are vertical on other 351's like windsors they are horizontal.
Old Jan 24, 2006 | 08:32 PM
Young_unn's Avatar
Young_unn
i had a 351M the only thing i could find to tell the difference was the sticker on it, but the heads were bigger im pretty sure
Old Jan 24, 2006 | 09:35 PM
Mike G's Avatar
Mike G
A 351M uses the big block bellhousing bolt pattern where the 351c has a small block pattern. The big blocks stretch 7 1/2" between the top two bell bolts (at the flat top), the small block is only like 5".
--Mike
Old Jan 24, 2006 | 11:32 PM
phat56's Avatar
phat56
Count the valve cover bolts: 6 bolts: 351W, 8 bolts: 351C
Windsor engine characteristics
-thermostat housing bolted to the front of the intake manifold
-351W's have intake bolts 90 degrees to the ground
-351W's have evenly spaced exhausts aimed 90 degrees from length of head Comparison of the 351C vs. the 351W fuel pumps
- The 351C bolts are verticle, 351W are horizontal
Cleveland engine characteristics
-the thermostat housing is on the block extension which contains the timing chain
-351C manifolds are dry, no water passages or thermostat housing....thermostat housing goes into the front of the block
-The Cleveland has the small 300/302/351W bell housing pattern.
Old Jan 25, 2006 | 12:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Identification (rev):
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
-There are other indicators but these are enough to distinguish engine families.
Both the 351C and 351M are 335 series engines. You can find more information in the 335 series engine forum.
Old Jan 25, 2006 | 10:08 AM
312's Avatar
312
as mike said the bell is different and the 351c takes 302 mounts.
gettler
46
Dec 16, 2019 02:51 PM
WillyV54
Dec 25, 2017 02:55 AM
LAKR45
General Automotive Discussion
Apr 13, 2004 09:12 AM
hellraiser
Jan 12, 2004 02:14 PM
dustinleavitt2000
Jan 5, 2003 01:34 AM
