Battery Drains
Old Sep 16, 2005 | 07:53 PM
rudy616's Avatar
rudy616
Talking Battery Drains
I have a 1995 Ford Ranger, 3.0L, 4WD. If I let it set longer then 3 days without starting it the battery is drained.
Is there some way to find a short in the system ? I have checked to make sure no lights were staying on. I was told it could be the computer.
Rudy
Old Sep 16, 2005 | 08:37 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
The best way to check for this type of a problem is to put an amp meter inline at the battery and see if there is an excess draw, the PCM has a very small drain, 0.05amps. If you find more then make sure you don't have a light, etc on, then start pulling one fuse at a time, remember you have two fuse boxes, until you find the problem circuit.
Old Sep 16, 2005 | 09:10 PM
rudy616's Avatar
rudy616
Battery Drains
Thanks for your help.
Rudy
Old Sep 17, 2005 | 07:44 AM
pawpaw's Avatar
pawpaw
If you don't have a multimeter to measure for excessive parasitic drain, which could be any of the things Ken outlined but could also include shorted battery cell/s, shorted or leaky alternator diodes, which are more dfficult to test for, why not consder running this ride by your favorite autoparts store, for a no cost electrical system checkup, via their portable electrical system tester.
It can properly load test the battery & alternator in the vehicle, to detect weak battery cells or alternator diodes, as well as check the electrical system for excessive parasitic drain.
Just another idea for consideration.
plum bob
18
May 31, 2018 12:06 PM
93f25073
35
May 23, 2013 04:04 AM
jetact
Sep 14, 2010 09:30 PM
jpj64
25
May 24, 2010 08:58 PM
Technocrsr
Feb 17, 2007 09:13 AM
