carburator to cfi?
Old Jul 8, 2005 | 10:07 PM
muscletruck7379's Avatar
muscletruck7379
carburator to cfi?
me and my dad have been putting together an 82 250, my dad seems to think it should get great gas mileage, mileage that a carburator wont get and multipoint fuel injection wont get, we have access to 2+ complete throttle body injection systems, and he seems to think that the throttle body will be a big help because my aunts old t bird did great on gas mileage (he seems to forget the fact that a car w/ high gears and an aod will do better that a f250 with 4.10's and a c6). so im asking is if the difficulty of the cfi is any harder or different than what i have heard and read about on the multipoint fuel injection(get a wiring diagram and lay out the harness after carefully removing it from the car, then carefully transefer it into the pickup that is recieving the system)
Old Jul 8, 2005 | 10:37 PM
ford390gashog's Avatar
ford390gashog
i think you would be wasting your time. just tune the carb up really good and you will be good to go.
Old Jul 9, 2005 | 03:49 PM
LxMan1's Avatar
LxMan1
Yep, if I was going to convert to EFI, I would go Multi-port. It's much more efficient. I personally would stick with a carb myself.
Old Jul 11, 2005 | 02:57 PM
Jharger's Avatar
Jharger
For a custom application, sure you can get EFI to work. But you'll likely need a custom chip or computer tuner. Whne you get everything bolted up, and if it runs well enough, bring it to a dyno shop where they can give you a wide band O2 A/F readout across your RPM range. Then a chip/tuner can be tweaked to fine tune it. Keep in mind you'll need to weld O2 adapters to your exhaust system. With a bit of tuning, trial/error, and more dyno tests, you might get 2-3 MPG more than using just a carb. Is that amount of work worth it?
Ranger80
Jan 18, 2012 06:09 PM
outlawkyote
Nov 1, 2011 05:33 PM
peganit2
Nov 24, 2009 04:15 PM
Henry_the_Ford
Apr 28, 2004 02:21 PM
Chtulu473
Mar 28, 2003 12:37 AM
