Sponsored by: Innova
subwoofer cone travel (for tight clearance install)
Old May 20, 2005 | 08:37 PM
rockinkcollins's Avatar
rockinkcollins
i have a 2000 ranger extended cab and want to fit a 10 inch sub under each little jump seat. i have the clearance for the mounting depth, but was wondering how much a sub cone/ surround moves in and out when it is turned up loud. i want polk mm2104s
Old May 21, 2005 | 09:22 PM
PyroBob's Avatar
PyroBob
http://www.polkaudio.com/car/specs.php?name=mm2104
This is Polk's specs on that sub.
The number you are asking about is the Xmax.
The mechanical Xmax is the physical distance the cone can travel, while the linear Xmax is how far the cone will travel within the magnetic field. Ideally the cone would never pass the linear point, however, better safe than sorry.
Hope that helps.
Old May 22, 2005 | 08:20 PM
rockinkcollins
thanks a lot man, that info was great
rangermann17
Jun 20, 2009 03:08 PM
bmusgrove
Jan 17, 2006 06:21 PM
fordtrucklover94
1983 - 2012 Ranger & B-Series
Sep 17, 2004 12:44 PM
modru2004
19
Dec 2, 2003 08:17 PM
shutout31
Jun 30, 2003 10:27 PM
