Sponsored by: Innova
97 Mountaineer Sub
Old Jun 29, 2003 | 02:17 AM
shutout31's Avatar
shutout31
97 Mountaineer Sub
I've got a 97 Mountaineer with JBL in which the sub has blown, and I'm looking for a quality replacement for it. This is the second sub that has died on me in the last 6 months due to a stressed connection between the cone of the speaker and the connector of the speaker. I'm not sure that I want to buy the same speaker and have the same thing happen to the new one, so what would you all suggest I put in its place that will put out some good sound? I'm still using the factory-installed amp, so please keep this in mind when making suggestions so as to not blow the amp. Thanks!
-Steve
Old Jun 29, 2003 | 02:14 PM
bluegrizzlies1's Avatar
bluegrizzlies1
97 Mountaineer Sub
solar baric kicker
Old Jun 30, 2003 | 12:11 PM
RBrendel's Avatar
RBrendel
97 Mountaineer Sub
with the factory amp you would not beable to push even a solo baric 8. you might beable to push a kicker comp 10. i would get an aftermarket amp with your new subs.
Old Jun 30, 2003 | 08:39 PM
PrPlayboy's Avatar
PrPlayboy
97 Mountaineer Sub
Almost sounds as if was a defect in the sub. The stock sub set up isnt that great to begin with. With that said, being your truck is a 97 I would look into a stealth sub box and put an amp to it. In total you will most likely be out $350-$400 but you'll be happy.
Old Jun 30, 2003 | 09:20 PM
optikal illushun's Avatar
optikal illushun
97 Mountaineer Sub
wow these subs seem like the blow easily...
Old Jun 30, 2003 | 09:40 PM
PrPlayboy's Avatar
PrPlayboy
97 Mountaineer Sub
Cause they r not controlable so just to hear them u need to turn the bass all the way up which with some songs makes them distort easy.
Old Jun 30, 2003 | 09:41 PM
optikal illushun
97 Mountaineer Sub
oh...why would ford put a junk sub in...makes me wonder...
Old Jun 30, 2003 | 10:27 PM
PrPlayboy's Avatar
PrPlayboy
97 Mountaineer Sub
It wouldnt be that bad if you could control the sub volume instead of raising the bass just to hear it
Araltd
Jan 6, 2011 09:29 PM
Araltd
Jan 1, 2011 11:40 PM
First Ford Truck
Oct 11, 2003 11:40 AM
bustedonce
Apr 18, 2003 10:40 PM
