slow to build boost
Old Jan 7, 2005 | 09:41 PM
mikeofwoodland's Avatar
mikeofwoodland
Question slow to build boost
I have a 97 7.3 and it seems to build boost slowly in 1st gear. Sometimes only 5#. In 2nd, drive and overdrive I reach 15#, but it takes the entire gear. Sometimes when its cold it takes an excessive amount of time going thru the gears, and when warm boost comes on very strong in all gears. Is this normal?
Old Jan 7, 2005 | 10:42 PM
sneak's Avatar
sneak
You just described my 02 350 to the T. I just did the 10K mod, it is surprisingly quicker from a stop. BUT, I still have questions about durability right now, I just did a post 5 min. ago, check it out.
Old Jan 7, 2005 | 11:49 PM
ltfox's Avatar
ltfox
You really only build boost under load. If the truck is'nt working(creating heat) boost will be low. Such as when in low gears. But in higher gears the truck works more to maintain speed or acellerate and creates heat which creates boost. Fuel=heat=boost
At least the way I understand
Old Jan 7, 2005 | 11:51 PM
ltfox's Avatar
ltfox
BTW.... about 17lbs is max boost for a stock early psd.
Old Jan 8, 2005 | 09:05 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Enjoy FTE …..
Old Jan 8, 2005 | 11:13 PM
realhp's Avatar
realhp
Did this problem just start or has this been going on for a while. If it only does it when it is cold outside it may be your EBPV being closed causing your low boost.
Old Jan 8, 2005 | 11:19 PM
barebackjake's Avatar
barebackjake
winter fuel dosnt help either, not as much power in winter fuel makes it lag a little more also. big exaust and intake and hot chip and some swamp babies will make that boost gauge jump good
Old Jan 9, 2005 | 10:35 AM
mikeofwoodland
it mainly does it when the engine is cool. After coming to a stop from a trip on the freeway acceleration is very good but can very quickly go back to no or low boost. Kind of sporactic. I pulled the rod off the waistgate to make sure it was free and it was, and thats all I have done. It has done this since I got the truck 3months ago. Thanks for the input.
Old Jan 9, 2005 | 01:24 PM
444dieselrod's Avatar
444dieselrod
The 97's didn't have a wastegate, that was our EBPV that you disconnected, which would lead me to think that was why it would boost slow when cold, but since you disconected it that eliminates that.
Do you still have the stock exhaust system, specificly the cat??? The cat is such a restrictive part of the exhaust, removing that will allow better exhaust flow which will result in higher boost at lower rpm's, and it will realy rev faster when you lay into it. at least thats what I noticed, I dont know for sure what it will boost in first, but will hit 16 in second and 20 at the end of third. a better intake system will help too.
The slow shifts, I assume happen when the truck is stone cold???? is that right. The converter will not lock until the engine is up to a certain temp, this could be what you are feeling, it does seem like it shifts slow when th econverter isnt locked.
Diesel Rod
Old Jan 9, 2005 | 09:34 PM
mikeofwoodland
No I do not have stock exhaust, 3 1/2 inch straight pipe out the rear. K&N air filter, everything else is stock, no chip, nothing. I installed a boost gauge last week and I don't climb over 16#. It does seem like all of my problems are related to engine temp. maybe I am looking for power I dont have. I appreciate any and all responses....thanks
Old Jan 9, 2005 | 10:07 PM
realhp's Avatar
realhp
Is your EBPV still disconnected? With out a chip you will not make much more boost than 16.
Old Jan 10, 2005 | 08:05 AM
mikeofwoodland
I reconnected EBPV in the same sitting. I went for a drive yesterday and was able to show my financial advisor (ol' lady) the issue, From a dead stop,Full throttle the truck cant get out of its own way with boost reaching only 5#. Next time, the truck sits you back in your seat with boost going to 15# before shifting to 2nd. I will chip it but I need to make sure I dont have problems a chip wont fix first. Thanks again
Old Jan 10, 2005 | 09:51 AM
realhp's Avatar
realhp
I would disconnect the EBPV and make sure it is open and run it for a while and see if your problem goes away.
Old Jan 10, 2005 | 10:17 PM
mikeofwoodland
I unhooked the intake pressure line and had only 3 or 4# all the time. I didnt unhook the three wires where the pressure line goes. Is that what to unplug or do I unplug the cylinoid atached the EBPV?
Old Jan 10, 2005 | 10:25 PM
realhp's Avatar
realhp
You need to unhook the plug that goes to the solenoid. I have seen Kwick post a nice picture of the plug you need to unplug.
06-Tugger
Nov 28, 2019 02:26 PM
rock2610d
Jun 16, 2017 07:47 AM
98wgefugfu3ebg
Apr 6, 2016 08:56 PM
Tugly
110
Oct 24, 2012 04:51 AM
MaxOut
Oct 19, 2009 08:12 AM
