The fuel inejctors are live ("electrically hot") all the time with battery power. After considering input from a variety of sensors and computing the best time and duration to operate a particular injector, the PCM supplies a ground which completes the circuit and results in the firing of the injector.
No pulse to all the injectors sounds like a common power problem (red wires are power, which originate from the PCM power relay).
What would happen if I applied +12 volts to fuel injectors by passing PCM module???
Better you should check to see if there's voltage there already, rather then just adding some.
If you don't know with good confidence what you're doing, electrically speaking, I wouldn't recommend feeding voltage to things to see what happens. Figure out what voltage is missing, and reapply it the right way (fuse, pinched/shorted wire, etc). Get a manual, or a friend who's electrically knowledgable.
If you just start jumping wires around, you might find "Oh, that's it, I need a new PCM. Mine's fried."
Well, it might not have been when you started...
Not a knock on you. Just learned the hard way, years ago.
