Bump when accelerating.
Old Sep 10, 2002 | 05:13 PM
Branrock's Avatar
Branrock
I have a 1998 ranger 4x4 supercab with an automatic transmission. When I accelerate from a stopped position it seems as if the transmission starts spinning briefly then there is bump as the truck moves away. This occurs just about everytime that I start from a stopped posistion. Sometimes under breaking I will feel the same type of bumping sensation. I have had the transmission changed (warranty) yet the problem still persist. Does anyone have an idea as to what could be causing this?
Old Sep 10, 2002 | 06:24 PM
rellik74's Avatar
rellik74
I have the same problem too, it kinda like it down shifts as you take off. I also have a new warrenty transmision.
Old Sep 11, 2002 | 08:50 AM
Ken00's Avatar
Ken00
There are several drive line TSBs, # 02-08-02 01-11-11 & 99-13-04, have you had the dealer check for these problems. I have most of the TSBs except the most resent, email me if you would like a copy.
Old Sep 11, 2002 | 09:02 AM
Ken00's Avatar
Ken00
Old Jul 24, 2004 | 01:02 PM
WA.Ranger's Avatar
WA.Ranger
Ken Could I get you to e-mail the TSB's for this problem please. Thank you, Jeff.
Old Jul 24, 2004 | 08:32 PM
Ken00's Avatar
Ken00
Check out the links in the tech info thread, there are two good threads on this topic. Let me know if you still need the TSBs.
Old Jul 25, 2004 | 02:49 PM
WA.Ranger's Avatar
WA.Ranger
Thanks Ken.
Old Jul 25, 2004 | 08:47 PM
99xlt4.04x4's Avatar
99xlt4.04x4
Also check out the "will the common driveshaft thump destroy anything" thread. It sounds like this is your problem.
Old Jul 26, 2004 | 12:45 AM
WA.Ranger's Avatar
WA.Ranger
I can't seem to figure out how to get around this site yet. I looked in the transmission threads but couldn't seem to find anything.
Old Jul 26, 2004 | 01:01 AM
el conquistador's Avatar
el conquistador
search for it in this forum not the transmission forum.
Old Jul 26, 2004 | 01:16 AM
goose213's Avatar
goose213
Sounds like you have a bowling ball in the box of your truck!
Old Jul 26, 2004 | 05:34 AM
BillC1's Avatar
BillC1
TSB regarding greasing the Yoke Spline on the drive shaft - My 2002 did it - dealer greased the spline - Trouble GONE.
Old Jul 26, 2004 | 06:07 AM
kotzy's Avatar
kotzy
This drive shaft spline bind problem goes back to 1958. I had a Fairlane 500 that did
this. Ford came up with a ribbed seal that got pushed onto the output shaft of the transmission and prevented the ATF from washing out the spline lube. Are they still
using the seal?
Old Jul 26, 2004 | 08:52 PM
Ken00's Avatar
Ken00
The thread I reffered to is at the top of this forum, called "technical information", in there you'll find some links on this problem.
g00d4me
Aug 21, 2015 09:28 AM
Austin Elliott
Mar 12, 2015 09:21 PM
LinuxMercedes
Nov 19, 2014 04:06 PM
tmarat
Oct 23, 2014 08:15 PM
ford1floyd
2004 - 2008 F150
Apr 13, 2012 06:59 PM
