rpm
Old Aug 21, 2004 | 06:56 AM
quickford's Avatar
quickford
rpm
Have 88 Ford F-250 7.3 diesel with c-6 automatic with a 4:10 rearend. Would like to know what rearend I could possibly use to get the truck to turn lower RPM's.
Old Aug 21, 2004 | 08:50 AM
fellro86's Avatar
fellro86
3.55 is a common one, many of the folks here can tell you about it more, My father's truck uses them, but there's many issues with that truck, maintenance(lack of) being top of the list...
Old Aug 21, 2004 | 08:26 PM
Dave Sponaugle's Avatar
Dave Sponaugle
3.55's work OK for me with a 4 speed
But it still turns lots of RPM's at interstate speeds. To have a good interstate cruising RPM a person almost needs an overdrive tranny.
2000 RPM 31" tires direct drive 4.10's = 44.98 MPH
2000 RPM 31" tires direct drive 3.55's = 51.95 MPH
2000 RPM 31" tires ZF 5 overdrive 4.10's = 59.19 MPH
2000 RPM 31" tires ZF 5 overdrive 3.55's = 68.36 MPH
The T 19 4 speed and C 6 were direct drive trannies
The ZF 5 5 speed diesel tranny was .76 overdrive
The M6HD 6 speed was .72
And the A4OD was .71
Old Aug 22, 2004 | 06:06 AM
bilder12's Avatar
bilder12
I had a gear vendors unit on my 88 and it allowed the engine to slow approximately 22% when it shifted into overdrive. I could shift in all 3 gears (c-6 auto) but first gear was realllllyyyy winding up the engine. The gear vendor unit would not shift til traveling about 23 mph to allow the speed sensor to work. The gear vendor unit can be selected to shift automatically or like a standard aux trans.
Old Aug 22, 2004 | 07:25 AM
Dave Sponaugle
I looked at those as well, but I think I am going to opt for the 5 or 6 speed tranny.
The gear splitting looks good, but you can only have under or over drive.
Using mine like I do I need more gears in both directions.
The 5 or 6 speed will give me a lower first gear and a higher high gear.
Money will be about the same either way.
diesel jim
Sep 17, 2013 08:40 AM
Poulsom
13
Oct 25, 2005 04:25 AM
Greywolf
Nov 11, 2001 02:27 AM
75fef100xlt
Jun 6, 2001 05:24 AM
dpattonfl
Mar 25, 2001 09:42 PM
