Sponsored by: Real Truck
DRL Module Location??
Old Dec 12, 2003 | 11:15 AM
elkfever's Avatar
elkfever
My 2000 F350 was originally sold in Canada, and is equipped with Daytime Running Lights (DRL).
I want to disable that feature, but am unable to find the DRL Module. I did identify the DRL Resistor which is located behind the driver's side headlight (as per Ford information). Ford information shows the DRL module to be located behind the glove box; I have removed the glove box, checked both sides of the firewall, but am unable to find the module.
Can anyone identify the module location please.
Any information will be appreciated.
Thanks
Old Dec 12, 2003 | 11:54 AM
oppy's Avatar
oppy
Why do you want to disable them? I kinda like mine.
I'll check my service manual when I get home and let you know if someone hasn't already.
Old Dec 12, 2003 | 12:17 PM
elkfever's Avatar
elkfever
Oppy,
I purchased a disabling adaptor from TYMAR for $8, and just want the option of running without daytime lights (for example when driving into hunting camp). Any info you can provide from your service manual will be appreciated.
Thanks
Old Dec 12, 2003 | 12:48 PM
oppy's Avatar
oppy
Good idea - never thought of that. So, the Tymar adapter is some kind of switch, or?? Sounds like a decent cheap investment.
Old Dec 12, 2003 | 01:48 PM
elkfever's Avatar
elkfever
Oppy,
The adaptor is a Ford part. Dale Isley at Tymar mentioned he had the used adapter plug when I ordered a Tymar Intake System for my Powerstroke Diesel. The adapter plugs into the wiring harness in place of the DRL module. You could probably obtain the part directly from Ford for their retail price of $16. Sorry but I do not have a part number, but the adapter plug is stamped FOEB-14A624-A.
Old Dec 13, 2003 | 09:16 AM
oppy's Avatar
oppy
Sorry I took so long to get back to you.
According to my service manual, the DRLs have 2 relays, both of which are at the left rear of the engine compartment in Auxiliary Relay Box 2.
I don't have a good diagram of it, but you should be able to tell which one you need by the pin configuration.
There is also a resistor near the left side headlight, but you already found that and it's not what you were looking for.
Good luck, and let me know how it works.
Old Dec 22, 2010 | 09:50 PM
erniek70's Avatar
erniek70
Is there an actual DRL module, or just the relays only? My headlights are not working properly (no low-beams, and high beams only with the manual headlight switch). I was told it MIGHT be the DRLs causing it. Any ideas?
Old Dec 23, 2010 | 05:19 PM
bunklash's Avatar
bunklash
"......just want the option of running without daytime lights (for example when driving into hunting camp)"
Is that because the elk can hear you coming if the DRL's are on?
Old Dec 23, 2010 | 06:14 PM
gearloose1's Avatar
gearloose1
"FORD F-150 Trucks Replace the DRL relay (located top of pass side dash) with a loop back plug (or modify it). But first try unplugging the dropping resistor (located at Left front of truck, underneath)."
DADRL - How To Disable DRLs
On my E series, unplugging the DRL module behind the grill did it.
Old Jan 3, 2011 | 05:03 AM
erniek70's Avatar
erniek70
removed switch, then re-installed. all lights worked for a bit, then low-beams stopped working again! DRLs are not working either.
Old Jan 3, 2011 | 05:18 AM
erniek70's Avatar
erniek70
Anyopne know where the DRL is on an '05 SD? Are they only controlled by the relays under hood? An actual module somewhere? Could it be the source of my problem?
Old Apr 17, 2013 | 11:02 PM
Ace_boy2786's Avatar
Ace_boy2786
There is no DRL Modules, only 3 relays tied into the headlights and a resistor. I am currently looking inot hooking them up but instead of to the headlights sending the DRL signal to the fog lights.
Old Mar 30, 2017 | 02:32 PM
jm-bc's Avatar
jm-bc
The relays are located above the glovebox on my 2000 F350. There are three bolts on the base of the glovebox. $1 to remove the bolts - $99 to know what bolts to remove. Ford did not make this obvious.
ojh
Nov 26, 2017 11:38 PM
Screwed 05
2004 - 2008 F150
Aug 31, 2017 03:03 PM
zarmo
Oct 25, 2016 12:56 PM
rxk9394
Sep 30, 2016 06:36 PM
ratedterror
Escape & Escape Hybrid
May 29, 2016 12:49 AM
