is it possible to remove lock cylinder without key
Old May 26, 2026 | 02:53 PM
jalls1's Avatar
jalls1
I have a very nice original ignition switch without the key. I tried to twist off the shiny chrome bezel piece but it won't turn beyond a certain point. I suspect that the lock cylinder must be removed first. I know how to remove them with a key and paper clip, BUT, is there any way to remove the lock cylinder w/o the key and without destroying the ignition switch? By the time I go to a locksmith I could probably buy a new aftermarket switch. This one is genuine Motorcraft.
Let me clarify, I am not opposed to destroying the lock cylinder but would like to save the ignition switch.
Old May 28, 2026 | 11:22 AM
Pickupmanx2's Avatar
Pickupmanx2
My best guess would be drilling out the lock cylinder... have you tried many keys in it? They are pretty simple, with I think 4 or 5 tumblers, I took one apart yrs ago to re-key it to match the door keys I had, the keys and the lock were very worn, so I didn't have to get it exact. But... if that no worky, I would take a drill bit, slightly larger than the key way and drill it out, then you should be able to get the tumblers out, then the paperclip trick.
Old May 28, 2026 | 06:11 PM
Nevada51's Avatar
Nevada51
I agree, I don't think you can get it out without the key. Definitely worth trying some other keys though. I ended up drilling my original one out as I lost the key...and then I found the key...
Old May 29, 2026 | 09:56 AM
Iowa Mike's Avatar
Iowa Mike
Sounds EXACTLY like my luck!
Old Jun 1, 2026 | 05:50 PM
66Classic96's Avatar
66Classic96
I was able to do it with a key that fits into the lock and jiggleing it. Takes some patience and a little time but i did get it out. They also sell sets called jiggle keys.
Old Jun 1, 2026 | 09:34 PM
66with352's Avatar
66with352
I refenced a video similar to this one when I had to get mine out without a key. It took a little bit but in the end, it wasn't that bad. I made my own tools. Once you get the cylinder to turn, then you can follow the standard instructions to remove an ignition cylinder in these trucks. I don't recall he exact sequence using the little hole in front and turning but there was no need to drill mine out. I was surprised that I was able to do it but like I said, it wasn't that hard. Good luck.
Ninety9
Dec 19, 2024 05:10 PM
Badair
May 4, 2010 11:56 AM
Poison Oil Racing
Jan 20, 2009 09:50 PM
sr1620
1997 - 2003 F150
Jan 21, 2006 09:10 PM
hungrymonkey
Sep 24, 2005 01:07 PM
