ignition lock cylinder
Old May 3, 2010 | 09:42 PM
Badair's Avatar
Badair
simple question... how do you get the lock cylinder out of and back into the ignition switch? I can't figure it out, I've been messing with them all afternoon
Old May 4, 2010 | 01:24 AM
bmuhlbach's Avatar
bmuhlbach
with the key in turn the lock there is a little button that you push in with a paper clip that allows the cylinder to turn a little more to lock into the switch part.I just did this last week It had me stumped to.
Old May 4, 2010 | 09:26 AM
68horses's Avatar
68horses
Badair,
I believe you turn the key counter-clockwise and watch/feel for the little button to show up in the little hole, push a paper clip into the hole to depress the button and continue to turn key till it stops and then pull out the key and lock cylinder all as one. Once it stops turning, you may need to wiggle it a bit to get it out.
HTH
Gene
Old May 4, 2010 | 11:56 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You have to remove the ignition switch bezel before removing the lock cylinder.
Plumzz
Mar 30, 2016 04:55 PM
akg123
Dec 14, 2015 03:36 PM
GMbusa
Dec 8, 2015 10:21 PM
B-DOGG
1983 - 2012 Ranger & B-Series
Mar 19, 2006 02:10 PM
