Sponsored by: Auxito
sr1620
Old Jan 21, 2006 | 02:39 PM
sr1620's Avatar
sr1620
Question sr1620
first time post. how hard to change ignition key switch on 1998 f-150 .steve
Old Jan 21, 2006 | 06:13 PM
preppypyro's Avatar
preppypyro
Easy as pie man.
Old Jan 21, 2006 | 08:10 PM
Racerguy's Avatar
Racerguy
Hi and welcome to the forum
Are you replacing the ignition switch or the lock cylinder where the key goes in? They are 2 different things on these trucks.
To replace the lock cylinder you turn the key to the run position and then stick a small pick or screwdriver in the hole in the trim piece under the lock cylinder to push the release button in. Then you just pull the cylinder out.
Old Jan 21, 2006 | 09:10 PM
sr1620's Avatar
sr1620
Smile sr1620
the lock cylinder . thanks racerguy
