Code recovery, ECM, MPG. Oh my
Old May 24, 2026 | 08:11 AM
b00mhower's Avatar
b00mhower
Trailering
Hello all, recently started driving my 91 F150 (300, E4OD, 3.08 rear, 2WD) again, until gas hit $5/gallon and I did the math on my fuel mileage...9 mpg, went back to the cobalt for a bit after that math.
That led me to see if I had any codes stored, my dash is inoperable at the moment so I can't jumper the self test and count flashes. This hasn't bothered me since I still have a speedo, and standalone oil press and temp gauges.
I didn't have an analog meter handy so I bought the Ford obd1 scan tool aaaand nothing ... It will initiate the self test, relays clicking and what not but no codes. Same story with the analog meter.
I have 5v at the self test connector but something isn't happy enough to flash my codes
Question being could this all be related? The dash issue and the no codes? ECM issue? Seems unlikely seeing as how the truck runs and drives seemingly fine except for my fuel mileage. Any ideas appreciated, thank you
Old May 24, 2026 | 08:30 AM
90project5.0's Avatar
90project5.0
If the scanner isn’t even giving the 11 code, then you need to inspect the computer itself. That’s a sign of it being bad.
Remove it and open the case. Look for leaking capacitors.
Old May 24, 2026 | 08:34 AM
b00mhower's Avatar
b00mhower
Trailering
I figured a failed computer would present with more symptoms than just not being able to pull codes but I'll have to look into it
Old May 24, 2026 | 09:00 AM
90project5.0
Usually, not necessarily though. It will be the computer or wiring from diagnostic port if you can’t get codes.
Old May 25, 2026 | 09:19 AM
manicmechanic007's Avatar
manicmechanic007
If it runs, it hasn't failed
There is a procedure for "no codes outputted" in the service manual
Could be as simple as a fuse out for the DCL of VIP self test connector
1991 PCED will have some info and the service manual too
I'd start with A EVTM and look over the circuit
I have a 1990 but it's probably different
Old May 26, 2026 | 03:12 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Hello all, recently started driving my 91 F150 (300, E4OD, 3.08 rear, 2WD)…my fuel mileage...9 mpg
Something is wrong with the EEC system. My ‘87 Bronco (302/C6) would get 14-15 mpg. Your truck should get fuel mileage in the mid to maybe upper teens.
Old May 26, 2026 | 03:38 PM
GoinBoarding's Avatar
GoinBoarding
Certainly different as my truck is a 1996 with obd-II, but it had a failed internal circuit in the PCM that made it lose Keep Alive Memory. So every start it was in relearn mode, with poor fuel economy and low power. New PCM and issues were fixed. It cleared codes every restart as well. It ran well enough that I just thought it was getting tired, not so bad I immediately knew there was a problem.
Old May 26, 2026 | 04:32 PM
My4Fordtrucks
When you turn the key from OFF to RUN does the fuel
pump prime and shut off or continue to run?
tigerhawk_212
1978 - 1996 Big Bronco
Jul 10, 2021 03:03 PM
ottawaguy
Dec 30, 2008 09:18 PM
mackedisto
Nov 28, 2006 10:32 AM
davetik
Aerostar
15
Dec 15, 2005 03:07 PM
bkampbel
Oct 7, 2005 04:53 PM
