KOEO/KOER 93nighthawk instructions
93nighthawk gave these instructions in an older post that I read:
Maybe I should start sticking my hands in people pockets for the amount of advice that I give out. [img]images/smilies2/devil.gif[/img]
I would do the test again.
I assume that you are jumping to get codes.
Get Aero to operating temperature.
Place the jumper wire in the test port.
Sit down in the drivers seat with pen and paper ready.
Turn the iginition "on" but do not start.
You should hear a bunch of clicks and the CE light will flash.
You will start to get your KOEO codes, write them down, remember that they will be two digits.
After it is done running the codes, start the vehicle. (KOER)
The CE will Flash to tell you to turn the steering wheel, push the brake, and hit the accelerator to about 1/2 way down.
Write down Codes.
When codes are done the CE will signal you to start the balance test (I think, if not go ahead and do the following)
Hit the gas to the floor, that will start the balance test.
You will get a two digit code (at least one).
Bring codes here for decifering.
I would not go with the first set of codes you pulled because they are iffy.
I don't understand the two digit code and how they display.
or attach a volt meter to diagnostics plug>
http://autorepair.about.com/library/...bl-dtcs-60.htm
http://www.midwestsho.com/catalog/tr...s=instructions
You might have to hit "What does it mean" a second time to have it come up. Also you can look up the two digit/three digit codes there.
According to the codes it is: Canister purge (CANP) circuit failure. Never heard of this, I will do a search, but if you have a clue, I'd sure appreciate your wisdom. Does this sound like a problem with lack of power/hesitation and poor gas mileage. Thanks
As for the charcoal canister, it is where the fuel fumes are "purged" before the air is released in the air. It is located in around the bumper somewhere (I can't recall exactly where.) If you have issues with your fuel pump or regulator, these tend to get clogged. Ussually it is another issue causing this.
You said "when you have problems with the fuel pump these tend to get clogged" are you telling me that when I find my cannister purge valve (somewhere by the bumper where fuel fumes are purged) I can clean it and that might fix my problems. Again, sorry for my ignorance in this area, but I really am trying to learn how to fix stuff on my vehicles. Thanx
The canister cannot be cleaned. It is like a water filter, once it is clogged, it needs replaced.
Codes from KOER:
13 - ISC did not respond properly (extends to touch throttle then retracts for KOEO) Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too high) ISC sticking open ITS circuit or TP sticking
21 - Engine Coolant Temperature (ECT) sensor out of range
73 - Rerun test if 73 is still output replace TPS No Throttle Position Sensor (TPS) change in "goose" test. Must get at least 25% throttle rotation
Ok it looks like your engine coolen temperature sensor is a gonner and needs replaced (that is one of the reasons that you are getting poor millage, the computer is stuck in warm up mode and running rich.)
Now 13 and 73 could be related in that you did not mention hitting the throttle so it was unable to do the TPS and IAB test properly. Or your TPS and IAB are toast, which is a possibility at that age, so I would re-run the KOER and hit the gas at least 1/4 throttle after the RPMs automatically go up (along with everything else but the OD button.)
One more thing you should know, due to your mentioning "ECT" is that my thermostat guage does not read at all. However, after sitting for a long time, I started the van and noticed that the guage worked, but I never got any heat. Finally, I realized that the water level in radiator might be low, sure enough it was about a gallon low. After filling it up again (with warm water) I got heat and my tempature guage quit working.
Let me know what you think, I am driving it to work tomorrow (45 miles one way) I filled it up tonight and will fill it up when I return.
12 - Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low)
18 - Check base timing & advance function (M) Ignition TACH signal erratic
The TPS could be bad, the Goose test is one of those that are hard to get right.
The ECT sensor is different than the sensor sending to the dash. It looks like it is toast and needs replaced, otherwise your fuel economy is going to stink, because the computer thinks it is at operating temp, but it is not.
18 I am not sure.
12, Try cleaning the IAB. common issue with Fords, if that does not work, it will need replaced.
Are you loosing coolant somewhere?
Did you remove the neg battery cable for about twenty minutes after replacing all that stuff? The old codes could be no longer aplicable if you did not do that which would effect engine performance.
In regards to my ECT and temp guage, are you telling me that the gauge is toast or the ECT is toast. If it is the ECT, is that a costly part, is it a difficult switch out?
On the throttle, I can only guess as to how much pressure I am giving, 25%, 30-35%, your probably right it is hard to guess right on that.
Lastly, what is the IAB and where is it located.
Thanks,
Dave
As for the CANP, probably a Ford only item, but I would wait a little bit before replacing until you have taken care of the ECT and IAB.
You never mentioned if you did run both KOER, KOEO and engine balance test?
Assuming that you read them right, here are what they mean.
17 - 1.9L & 2.5L - Throttle stop set too low
As for the 7, I don't know, all codes are two digits, not single digits. To do the balance test, you just hit the gas when it is done giving you the codes during the koer and it will start dropping sylinders, then give you a two digit code.
I would also check to your vacuum tree to see if any of the lines came loose, that might also explain your poor running, along with replacing the CANF, sense that seems to be an issue.
Again, thanks for your wisdome,
Dave
