1978 - 1996 Big Bronco
Bogus OBD1 codes
Old Jul 10, 2021 | 12:57 PM
tigerhawk_212's Avatar
tigerhawk_212
Bogus OBD1 codes
I've been having a sort of random issue lately. I've been running KOER tests and it's showing me many fake codes. I get codes that aren't even listed in the book at times, like code "9". It's different each test. I ended up buying a new code reader to see if there was a difference and it's the same scenario. I also tested another ECM for another purpose and the same thing... Grounds are good. The next thing I might check is corrosion at the test terminal. Anyone run into this problem before? I suppose it isn't "hurting anything", but still trying to figure it out.
Old Jul 10, 2021 | 03:03 PM
My4Fordtrucks's Avatar
My4Fordtrucks
1) Why are you running KOER tests? If there is something wrong you do the KOEO self test and repair anything there first.
2) What fake codes are you getting?
Treytaw
Apr 19, 2013 06:23 AM
bbryson
General Automotive Discussion
Jul 7, 2011 12:33 AM
ottawaguy
Dec 30, 2008 09:18 PM
bkampbel
Oct 7, 2005 04:53 PM
Jrock909
Nov 28, 2004 07:07 AM
