1963 F-100 front wheel cylinders
Old May 16, 2026 | 01:23 PM
WrongBed'sWrath's Avatar
WrongBed'sWrath
5th Gear
I'm looking to replace the shot single piston wheel cylinders on my 63 with dual piston cylinders. Is this a simple drop-in conversion? If so, what wheel cylinders should I get? I'm already completely redoing the brakes since it hasn't moved in 40 years and do not have the funds to convert to front discs. I'm just trying to get it back on the road with working brakes.
Thanks in advance
Old May 16, 2026 | 02:47 PM
TA455HO's Avatar
TA455HO
Lead Gopher
Sounds like people buy the dual piston wheel cylinders for 1964 and replace them. I would have thought backing plates wouldn't have the right holes to bolt it to but maybe it's exact.
Replace single piston wheel cylinders. - Ford Truck Enthusiasts Forums
Old May 20, 2026 | 05:34 AM
38 coupe's Avatar
38 coupe
I did a complete brake job on my 63 F-100 and don't remember anything about single piston wheel cylinders. My brakes were typical Bendix units with typical opposed piston wheel cylinders. I got my parts from Rock Auto since it is much more cost effective than the local auto parts chain store. I didn't take any pictures since there was nothing unique or interesting about the brakes, other than I think the hoses were original from 1963.
Can you share what applications got the odd one piston wheel cylinders? My chassis parts catalog illustrations section shows typical two piston setup for 57-63 F-100.
Old May 20, 2026 | 09:26 AM
TA455HO's Avatar
TA455HO
Lead Gopher
In the thread I posted a link to above @NumberDummy gives the applications. This should take you to his posting. If you disagree, you'll have to take it up with him.
Old May 20, 2026 | 09:33 AM
rusty valley's Avatar
rusty valley
my 61 f100 got new rock auto brakes last year, and it also had normal 2 piston cylinders
Old May 20, 2026 | 10:04 AM
TA455HO's Avatar
TA455HO
Lead Gopher
If you read the @NumberDummy post that I linked to above he does say
Dual pistons: C1TZ-2061-A Right & C1TZ-2062-A Left ... Wheel Cylinders / Obsolete
Applications: 1961 F100 2WD, 1962 F100 2WD before serial number 260,001.
I never followed 1961-1963 nearly as much as I did 1964-1966 so I'm not weighing in on this one.
Old May 20, 2026 | 09:46 PM
38 coupe's Avatar
38 coupe
Please appreciate I am not trying to disagree with NumberDummy, he has more experience with Ford parts catalogs than anyone else on this forum. I re-read the Ford Truck Parts Catalog this evening and found the note he referenced, it is only in the text section not in the illustrations section. This is likely a problem of having the large digital catalog that covers many years, I suspect a truck catalog printed in late 1963 would show the odd single piston wheel cylinders in the illustrations. This type of thing is why I have multiple parts catalogs covering the years of the vehicles I am most interested in; the large multi-year catalogs have the last parts that Ford identified for use while the one released that year or very close to it shows the first parts that Ford identified for use. I occasionally get NOS parts very affordably by using the earlier part number from a print catalog when most people only have the digital multi-year catalogs.
Old May 20, 2026 | 10:02 PM
Nevada51's Avatar
Nevada51
The brake shoes on the OP pic have a spots for both pistons - not sure about the wheel cylinder bolt hole pattern, but my 1962 F100 has the two piston cylinders. I think I just ordered from LMC and I don't recall there being any option for one or two piston. My serial number is 251XXX FWIW.
lah2420
Apr 10, 2023 01:21 PM
jerryst
Feb 25, 2022 03:44 PM
63trogan
Dec 5, 2007 04:32 PM
retroluxe
Aug 30, 2007 06:35 AM
showle
Jun 3, 2002 04:12 PM
