Sponsored by: Real Truck
Crate Engine from Ford
Old May 14, 2026 | 10:45 AM
GN1220's Avatar
GN1220
So, as I continue to battle a random misfire in my 5.4, it got me thinking about replacing the engine. My truck is near mint condition, regardless of the odometer showing 213,000 miles, so I would like to hang onto it. I don't use the truck for work like I used to, but it's my daily driver. Logic says, just fix the misfire. Believe me, I'm trying. But having this issue appear randomly every few weeks or months, changing coils, wrenching under the hood has gotten old. Not to mention the heads have had inserts put in them and that issue is always in the back of my mind, too. And she's been using more and more oil lately. Get a new truck. I like having a truck, as it is handy, but I don't need a $40,000 + truck or payment and I don't want to start over with someone else's problem. I called Ford this morning and to my surprise, I can still order a brand new engine from my local Ford dealer for $5,332.00. To me, that seems like a pretty good deal. Just swap over my brand new intake, another new set of coils and accessories, and I should be good to go until I keel over. But I have a question that the parts guy couldn't answer so I'm hoping someone here can; Did Ford make any improvements to the heads on these regarding the plugs blowing out like mine did? It would really suck to have that happen on a new engine. I guess now that we know of the issue, just tighten the plugs a bit more before putting the new engine in, maybe? I don't know. Share your thoughts with me and let me know if anyone has gone the brand new engine route
Old May 14, 2026 | 11:38 AM
marksman76's Avatar
marksman76
Is it really a brand new engine?
Ford used to make re-man short and long blocks?
I'm sure if you did some more research, it is likely Ford improved the engine problems on later model engines.
You would have to find that out and then order one from that newly improved era, providing it would be a direct fit.
Old May 14, 2026 | 02:35 PM
GN1220's Avatar
GN1220
I want a direct replacement. Ford went to the 3 valve in 2004, so not many years to develop improvements. And the 3 valve has it's own share of problems.
Old May 15, 2026 | 02:58 PM
Pikachu's Avatar
Pikachu
Unless the misfire is caused by a base engine mechanical problem, you'll probably be chasing the same misfire again, but on a new engine.
Old May 18, 2026 | 10:49 AM
GN1220's Avatar
GN1220
There is that possibility, too. That's what makes this random coil pack issue so frustrating.
Old May 18, 2026 | 12:11 PM
Mike Langlois's Avatar
Mike Langlois
6th Gear
We just put in a new Ford crate motor yesterday; it took a few days. It was 6.8L V10 in a F5500 2009. It is quite a job and the motor was supposed to be new from ford and looked like it. We paid $8.5K in the Peoples socialist Republick of California. It started on the first turn of the key and is running smoothly. You can't go wrong with factory parts (once you get the correct one)).
Mike
Old May 19, 2026 | 10:28 AM
Super Duty DJ's Avatar
Super Duty DJ
@GN1220 , I believe this will answer your initial question about the spark plug blowout issue. It seems that in November of 2002, Ford updated the heads from having only 4 spark plug threads to having 8 spark plug threads for the 5.4 in order to address the spark plug blowout issue. It also seems like there may have been a revised spark plug design/model used in these newer cylinder heads. You would likely need to verify the casting dates on the cylinder heads of your "new" Ford engine or remove a spark plug and count the number of threads in the cylinder head to verify that you got the updated heads.
https://www.justanswer.com/ford/5znx...nder-head.html
Old May 21, 2026 | 09:13 AM
GN1220's Avatar
GN1220
I wish I knew that in 2016 when I had the heads off getting inserts put in them. Would've save a lot of frustration and worry.
Old May 26, 2026 | 01:27 PM
Brons2's Avatar
Brons2
Have you done a compression test on the existing engine? Had the valve covers off to inspect the valvetrain?
Old May 26, 2026 | 01:41 PM
GN1220's Avatar
GN1220
Yes, a few years ago. 😄 I just can't figure out this random miss that comes and goes. I understand, like was pointed out above, if it's an electrical issue that it will do the same with a new engine. It's just frustrating.
Old May 26, 2026 | 07:27 PM
ashleyroachclip's Avatar
ashleyroachclip
Last picture is at the least a burnt valve ?
Old May 26, 2026 | 07:36 PM
Pikachu's Avatar
Pikachu
It's definitely a little short of metal . . .
Old May 26, 2026 | 08:58 PM
GN1220's Avatar
GN1220
Yep. I bought it off ebay from Tacoma and the dealer said it ran great. Shipped it to Kansas City and it had a miss. Discovered a blown plug and a ****ty repair. Ended up pulling the heads and having inserts installed. That was in 2016.
theEmp
2004 - 2008 F150
Sep 19, 2018 09:02 PM
442w30
2004 - 2008 F150
Jan 6, 2011 11:25 PM
lee3
6.4L Power Stroke Diesel
Oct 14, 2007 02:04 PM
jimford1
Apr 17, 2007 10:44 PM
Ford Fan First
Feb 19, 2004 05:28 PM
