Mysterious oil leak
Old May 10, 2026 | 04:28 PM
Kyle5647's Avatar
Kyle5647
Mysterious oil leak
I am having a really difficult time figuring out where this oil leak is coming from..it appears to be from the top part of the engine because it leaks down in between the oil pan and starter. Here's the thing, valve cover gaskets are new and dont leak, that plug thats on the back of the cylinder head isnt leaking, no leaks in the engine valley and rear main isnt leaking.. also verified turbo pedestal isnt leaking (its new with new o rings)
Old May 10, 2026 | 04:39 PM
rusty1161's Avatar
rusty1161
It may be diesel from the fittings on the rear of the heads. These o rings go bad, especially how old these trucks are. https://dieselorings.com/products/7-...l-line-sleeves
Old May 10, 2026 | 04:59 PM
Kyle5647's Avatar
Kyle5647
Would that cause an oil leak or are you saying its a diesel leak? Its modt definitely an oil leak. Ive cleaned the area off multiple times
Old May 10, 2026 | 05:13 PM
rusty1161's Avatar
rusty1161
I had what I thought was an oil leak. Checked everything related to oil, last thing to check was the rear main seal. Ended up finding multiple diesel leaks from my e-fuel hoses in the valley. That fixed my “oil” leak.
Just sharing my experience, went down the same road as you.
Old May 10, 2026 | 05:25 PM
Lepidopterodactyl's Avatar
Lepidopterodactyl
Did you check your EBPV actuator? Mine was leaking like hell when I pulled my turbo. Easy to mistake for a pedestal leak.
Old May 10, 2026 | 05:45 PM
Kyle5647's Avatar
Kyle5647
Thats been removed. New pedastal, new kc turbo, up pipes etc..I will check the diesel leak for the hell of it but its a fairly bad leak and it doesnt smell like diesel. I get almost 13mpg with a 6k trailer so I dont think I have any leaks
Old May 10, 2026 | 05:47 PM
Kyle5647's Avatar
Kyle5647
This is why im so stumped about it. The top of the engine is completely leak free. Its also getting the transmission bolts wet too so idk..pulling my hair out with this one
Old May 10, 2026 | 05:56 PM
Kyle5647's Avatar
Kyle5647
Honestly its probably the rear main seal housing..thats literally the only thing It could be..
Old May 10, 2026 | 06:28 PM
INFRNL's Avatar
INFRNL
not true...it could also be the big oil galley plugs on the ends of the heads. could be valve cover gaskets
If you can't find the source, clean everything up and put UV dye in your oil, you will find the source and you don't even necessarily need a black/ UV light...but it's definitely helpful
Old May 10, 2026 | 06:56 PM
Kyle5647's Avatar
Kyle5647
Already checked the big plugs and valve cover gaskets are new but i still checked them to be sure. I have cleaned everything up twice and unless im retarded the only thing that I cant check unless the transmission is removed is the rear main seal housing.
Its leaking down the upper engine through that leak hole in between the starter and oil pan. Ive ruled out everything on the top end. Its not the rear main seal because the oil pan is completely clean. Only thing that would make sense is the rear main seal housing and its the only thing i cant check without removing the transmission
Old May 10, 2026 | 08:23 PM
Lepidopterodactyl
Is your fuel bowl/stock fuel pump still in place? Has your HPOP ever been pulled/resealed? I understand you say you've ruled out the engine valley, but there are a ton of leak points in the stock fuel/HPO systems. Your rear main seal wouldn't be getting your transmission bolts wet. I originally assumed that my truck was leaking diesel until I pulled my fuel bowl, at which point I learned it was a 70/30 diesel/oil mixture.
Old May 10, 2026 | 08:34 PM
Kyle5647's Avatar
Kyle5647
Yes actually the hpop has been when i did the turbo. The valley has no oil in it and the first time i attempted to find the oil leak i plugged up the weep holes with towels just to see and after a week they were totally dry.
walkerp
Nov 19, 2023 02:04 PM
OBSRAVONA
Oct 7, 2022 12:11 AM
eire49
13
Jul 5, 2022 08:33 AM
Supernesguy9000
Jun 4, 2022 07:50 AM
cgph4693
6.7L Power Stroke Diesel
Jun 2, 2020 10:22 PM
