Sponsored by: Auxito
98 F150 steering tilt pin location
Old May 4, 2026 | 01:59 PM
rudispruell's Avatar
rudispruell
1st Gear
Hello, All.
I'm a FNG, here, so treat me kindly, please. If you don't, I will find you and embarrass you in front of your Mom, and her friends!
Reasonably experienced. Worked on my own all my adult life. My ignition actuator retired without giving notice. Column lock cylinder just freewheels. I've never had to go this deeply into my steering column, before.
Ive torn into it, and gotten to where i have to break apart the tilt mechanism. Y'all recommend the vid I had been being guided by, but there's too much hand action and not enough parts location.
I've pulled the two T30 screws that hold the mechanism in place. Next step is supposed to be to pull the pivot pins, but nothing seems fit them. I tried every SAE and metric screw i had, as well as my tap, in both. I even went and bought the Lisle remover. No joy.
now I figure I'm in the wrong place. The online replacement pins look like what the bare end of the T30s fit into. But, I must wrong! Nothing would fit or start threading.
The dealership was a complete dead end. I am hoping someone knows this mechanism and can advise me. Help me, Obi Wan! You're my only hope!
Old May 5, 2026 | 10:23 PM
manicmechanic007's Avatar
manicmechanic007
You probably ought to go to your library and see if they have free AllData for you to use
The tear down procedure for your 1998 column will be in there
There are also videos you should watch
Not an easy job for the gears contacting the ignition switch actuator
You can do it, I'm getting good at it by now, I've done hundreds of actuators
Watch this video on Youtube
These are the tilt pins you must remove
VinnieSinatra
Oct 30, 2018 04:39 PM
juna106
Apr 15, 2016 04:43 PM
88'f150_300
15
Nov 13, 2004 05:51 PM
efritsch
Sep 23, 2004 12:46 AM
statesboro_blues
Jun 20, 2003 08:48 AM
