Hole in pick up tube or vapor locking?
Old Apr 19, 2026 | 07:18 PM
moto_hero's Avatar
moto_hero
All
When my truck gets below half, maybe 3/8’s of a tank, it starts to act like it’s starving for fuel. You can’t run watch the AFR gauge and it goes lean and the rich when it catches up. It is one hundred percent dependent upon how much fuel
is in the tank. As soon as you fill it up the problem goes away.
The tank is a LMC reproduction tank. I’m wondering if there is a pinhole or something in the pickup tube in the tank that’s around that 3/8’s mark or if it’s vapor locking?
Any ideas?
Old Apr 19, 2026 | 09:19 PM
1971f1004wd's Avatar
1971f1004wd
Sounds like the pickup tube to me.
Old Apr 19, 2026 | 09:49 PM
blue68f100's Avatar
blue68f100
I agree. Sounds like a pickup tube problem.
Old Apr 20, 2026 | 10:33 AM
moto_hero's Avatar
moto_hero
I’m wondering if I should just buy a new tank or try and repair and or dig into what I have.
Old Apr 20, 2026 | 12:08 PM
blue68f100's Avatar
blue68f100
How old is the tank? Maybe contact the mfg, for warranty claim.
Old Apr 20, 2026 | 12:43 PM
moto_hero's Avatar
moto_hero
I bought it from LMC in 2018 so likely it’s past that.
Old Apr 21, 2026 | 12:08 PM
fe390pc's Avatar
fe390pc
I would look into repairing what you have. Just not sure how? Pull the sender out and make sure the tank is above the level you are having the issue at. Then apply a little pressure through the pick-up tube and see if you can locate the leak? Once located, the hard part will be the repair. But finding the issue should be the first step. If there isn't a leak, something else is causing your problem.
Old Apr 21, 2026 | 12:28 PM
blue68f100's Avatar
blue68f100
Is your fuel cap not venting? When you release the cap do you hear any hiss or sound indicating a vacuum?
Old Apr 21, 2026 | 01:37 PM
moto_hero's Avatar
moto_hero
that’s a good way. I think I’ll try that.
Old Apr 21, 2026 | 01:39 PM
moto_hero's Avatar
moto_hero
it appears to be venting. No indications of vacuum
Old Apr 23, 2026 | 12:32 PM
fe390pc's Avatar
fe390pc
Good luck with your testing.
iontkendall
Dec 21, 2010 04:53 PM
gradyc
Mar 10, 2010 07:20 AM
PaysonPSD
Mar 2, 2008 11:46 AM
FitchBanjos
Feb 28, 2008 07:36 PM
brider
Jun 28, 2005 11:17 AM
