1978 - 1996 Big Bronco
460 Swapped Bronco W/ 4" Lift Coil Spring Too Soft
Old Apr 1, 2026 | 08:09 AM
AOP2024's Avatar
AOP2024
5th Gear
Howdy Yall!!
I swapped a 460 into my 87 Bronco and put a 4" lift on her (4 Bilstein front shocks). The problem I'm experiencing is the front end is extremely soft. Can anyone recommend any stiffer coils for the front end? Any help is appreciated. Just to re-itterate, this is not a shock issue, the springs just cant keep up.
Old Apr 1, 2026 | 01:08 PM
My4Fordtrucks's Avatar
My4Fordtrucks
You can answer this yourself. What is the spring rate on the coils from the kit? Did you try asking the lift kit manufacturer?
Old Apr 2, 2026 | 06:38 AM
manicmechanic007's Avatar
manicmechanic007
Post pic of lift kit
Agree, find out what springs are on it and go bigger
I had to use Ford springs at the dealer, and they made 40 or so different spring rates
Of course, I was fighting body lean but you just get yourself some heavier springs
Old Apr 3, 2026 | 10:24 AM
stephen.osborne1's Avatar
stephen.osborne1
I wonder if f250 2wd springs would work?
Old Apr 3, 2026 | 04:27 PM
My4Fordtrucks
Stock replacements won’t since the OP installed a 4” lift kit.
Old Apr 3, 2026 | 08:45 PM
stephen.osborne1
Yeah, but 4" f250 springs may work great.
Old Apr 4, 2026 | 06:30 AM
My4Fordtrucks
Not that there aren’t any but do you have a source and part number for a 2wd F250 lift kit? Does it list different springs if you have a diesel/ 460 vs 300/302/351?
Old Apr 4, 2026 | 10:15 PM
stephen.osborne1
No, I don't. It seems I used to see them listed, but haven't looked for years. I bet the Google Gods may provide.
coleprout
Feb 14, 2018 11:59 PM
tjames001
2004 - 2008 F150
Aug 4, 2012 09:47 AM
Desert Dog
Bronco II
16
Dec 15, 2006 09:39 AM
Dustin_86
Mar 10, 2005 08:09 AM
bigredbeast90
20
Aug 15, 2004 12:00 PM
