No Crank, No Start - not the usual suspects.
Old Feb 10, 2026 | 02:04 PM
Cyanide6's Avatar
Cyanide6
Trailering
Edited for clarity, edits are in italics
Hello All, long time member who took a hiatus. Now I am back with an interesting, "intermittent" no crank no start.
Truck is a 2008 F-150, 5.4L Lariat 4wd Crew with the 6 foot bed. 90,9xx miles and from what I can tell, a relatively easy life for Alaska.
I bought the truck in late October and was able to drive it around a bit starting in late November due to it being at the detailers for a mold remediation issue. Truck started consistently, then it didn't start one day, acted like a dying battery and the truck had been sitting for at least a year so I chalked it up to a bad battery and didn't think anything of it. I assume a new battery is part of every vehicle acquisition, I lump it in with new fluids, etc. so I replaced the battery. We had a warm for us fall /early winter, everything was fine until the weather got colder then it started no crank no starting. I have been slowly messing with it and this is where I am currently.
  • Not PATS, key proves out. Red light flashing, solid, then out.
  • Not a relay, verified all relays in the passenger kick panel are working. Actuating and also passing current.
  • Not a fuse, verified all fuses in the passenger kick panel are working, and the problem is intermittent.
  • Start sequence runs out as it should, can hear the relays clicking, and fuel pump is priming consistently. It just doesn't attempt to crank at all.
  • Pulled the PCM and brought it inside to warm while the rest of the truck remained cold. (saw a post about a crack in the PCM solder that would separate enough when cold) No change, still no crank no start.
  • Starter was replaced within the last 600 miles by a shop for the previous owner. Notes from that visit, state that the old starter was pulling 475 amps so they replaced it. No indication if they tested any of the wiring to the starter.
  • Solenoid signal wire is getting a sloid 12v+ when attempting to crank
  • Positive between battery and starter shows same voltage as battery. Same wire ohmed out at 0.03 (battery disconnected, tested from battery end of the positive wire to starter stud) seems high for less than 3 feet of wire, but would not think that 0.03 ohms is enough resistance to cause a no crank no start.
  • No clear correlation (that I can tell) to when it will or won't start.
    • I have started it at -40°F first time and had it not start at +10°F. Although, so far, if it does start the first time, it will restart again, at least within 3 hours.
    • Appears to only be a cool/cold weather issue, did not start doing this until after the temps were consistently below freezing.
  • When it does start, it starts good and strong. When it does crank, it starts, and starts normally. No extended or slow cranking.
  • Zero codes in the PCM for anything start or PATS related
Thanks in advance for the help and any thoughts or ideas are appreciated.
Last edited by Cyanide6; Feb 11, 2026 at 12:02 PM. Reason: for clarity, and to thank people for any ideas or thoughts.
Old Feb 11, 2026 | 10:49 AM
Hoghntr's Avatar
Hoghntr
Trailering
I bought the truck in late October and was able to drive it around a bit starting in late November due to it being at the detailers for a mold remediation issue. Truck started consistently, then it didn't start one day, acted like a dying battery and the truck had been sitting for at least a year so I chalked it up to a bad battery and didn't think anything of it. I assume a new battery is part of every vehicle acquisition, I lump it in with new fluids, etc. so I replaced the battery. We had a warm for us fall /early winter, everything was fine until the weather got colder then it started no crank no starting. I have been slowly messing with and this is where I am currently.
  • No clear correlation to when it will or won't start.
Have you checked the fuel pressure at the fuel rail, just because you hear the fuel pump doesn't mean it's getting correct fuel pressure, also do you have spark at the plugs one more thing pull some gas out some gas to see if there is water in the fuel
Old Feb 11, 2026 | 11:54 AM
Cyanide6's Avatar
Cyanide6
Trailering
Thanks for the suggestions Hoghntr! Fuel pressure and spark aren't in the start circuit, so they shouldn't be a concern in a no crank, no start. Unless there is something I am missing? I should get extended cranking and no start if spark or fuel were the issue. When the truck does decide to crank it fires off normally. No delay, no slow crank, so I have good spark and decent fuel pressure.
All the old fuel was removed from the truck prior to getting it up and running again, and it has been filled with fresh fuel from a high volume station. Lucky for us, we don't have gasohol in most of Alaska.
Old Feb 11, 2026 | 12:39 PM
WWR's Avatar
WWR
Did I miss NSS? Will it start in N?
New starter means nothing. Is a trigger signal getting to the starter solenoid? This is the first thing we need to know.
Old Feb 11, 2026 | 12:42 PM
WWR's Avatar
WWR
It's unlikely at 90k but the shifter cable on our '08 came out of a "bendy" metal keeper on the firewall and then melted on exhaust. Shifts became vague and positioning of the shifter lever relative to actual gears at the transmission lever/MLPS was out of whack.
All this to say, are you really in P or N when you think you are?
Old Feb 11, 2026 | 03:04 PM
Hoghntr's Avatar
Hoghntr
Trailering
Sorry I thought it read crank no start
Old Feb 11, 2026 | 03:14 PM
Hoghntr's Avatar
Hoghntr
Trailering
I would check all your grounds also take a pair of jumper cables and clamp on a clean spot one the engine block and the other to the - battery terminal if it starts you know you have a ground problem
Old Feb 11, 2026 | 05:14 PM
projectSHO89's Avatar
projectSHO89
Good. This tells us the PCM is completely happy with both PATS and the transmission shift lever position and is telling the starter motor to crank it up. You now need to focus on the starter motor as well as it's supply voltage and ground. One of those three is missing.
Conduct this voltage same test with the starter trying to crank. Do NOT try and make a resistance check on a powered circuit.
You're going to need to test both the battery feed as well as the ground circuit UNDER LOAD. If both pass, pretty likely it's a bad starter.
Old fart's tip that was learned the hard way: Never leave the parts store with a starter or alternator until you've seen it tested on the bench. I've had more than my fair share of bad parts straight from behind the counter and this has saved my bacon a couple of times.
Haggis 6.2
Feb 5, 2023 08:23 PM
Fiveacre
Apr 28, 2022 09:19 PM
teae7982
2009 - 2014 F150
Jan 29, 2022 07:33 AM
Jakedog1996
Jul 23, 2014 05:59 PM
RhondaBruce
Dec 13, 2010 09:33 AM
