Surging idle & stalling
Old Feb 6, 2026 | 08:47 PM
sk47ft's Avatar
sk47ft
2nd Gear
Hello; I am new to this forum. I seek help with an issue in a 2007 F-150 with the 4.6 V8. Under 100K miles. Truck has been having an intermittent issue of low and fluctuating idle after warming up. Idles normally when cold. When warmed up the idle surges between 300 to 600 RPM range. Has stalled and died when coming to a stop sometimes. Have run some fuel injection cleaner and fresh fuel. The engine ran normally for a week or so then started the erratic low idle with stalling again.
Am thinking of using some Seafoam intake cleaner. (the sort with a small, curved straw) but have not done so yet.) The truck was bought new and is a one owner.
No check engine lights. Have not yet done a code reader.
I get this is sketchy information and hope to post more soon.
Old Feb 8, 2026 | 09:50 AM
WWR's Avatar
WWR
Clean the tb and disconnect the battery to reset throttle trims. It may stall a couple times once power is restored, so use caution when driving. My '07 once stalled several times after losing power.
If this doesn't work then look for vac leaks, lean codes, MAF codes/live data etc. Could maybe be FPDM, too -- although this is much less likely
Old Feb 12, 2026 | 11:09 AM
sk47ft's Avatar
sk47ft
2nd Gear
Hello; Cleaned the throttle body & intake with seafoam as per instructions. Been a couple of days but is doing OK so far. Will take a while to be sure. Thanks
23XL
Jan 24, 2024 05:10 PM
SteevenH
1997 - 2003 F150
Jun 19, 2010 10:25 AM
LambertMorgans
Mar 2, 2009 07:33 PM
big_tuff
1997 - 2003 F150
Dec 6, 2006 10:05 PM
RangerPilot
1983 - 2012 Ranger & B-Series
Sep 27, 2006 06:13 PM
