New Brake system, calipers locking on test drive
OUT FOR ANOTHER TEST, AGAIN, IT IS LOCKING UP, SO WHEN i GOT BACK TO THE DRIVEWAY, ....... i SPRAYED WATER ON THE FRONT AND REAR WHEELS, THE 3 WITH NEW PADS, ROTORS , AND CALIPERS, WERE ALL SMOKIN HOT, , WHICH WHEN TEST DRIVING BARELY GETS YOU HOME.
WHAT IS THE f*** ING PROBLEM.
WHEN REMOVING THE WHEELS, AND PULLING THE CALIPERS, FOR REPLACEMENT, THE ROTORS TURN FREELY NO BINDING , ONLY AFTER TEST DRIVING DOES EVERYTHING GET HOT, AND START LOCKING UP?
SO..... AM STARTING TO THINK THAT EITHER i HAVE THE WRONG PADS, THERE IS NOT MUCH MORE TO REPLACE. THE TRUCK WAS FINE,,,,, WHEN I DECIDED TOO REPLACE THE PADS, AND ROTORS ON THE FRONT. HAD A LEAKY LF BRAKE LINE, SO STARTED REPLACING THE WHOLE SYSTEM.....????
SO OPEN TO TAKING OPINIONS, AS IT SHOULDN'T BE THIS DIFFICULT.....TO CHANGE A BRAKE SYSTEM WITH ALL NEW COMPONENTS, AND HAVE THIS.
WHEN COOL, AND TAKING FOR A TEST DRIVE, i PUT IT IN NEUTRAL, AND COAST, NO NOISE ROLLS EASILY. ONLY AFTER YOU DRIVE IT A HALF MILE, DO YOU NOTICE THAT IT NO LONGER COASTS, AND STARTING TO LOCK UP, AND YOU BARELY CAN GET IT HOME, WITHOUT SITTING ON THE ROAD, DUE TO ALL THE CALIPERS, LOCKING TO THE ROTORS??????
COULD IT BE, THAT EVEN WITH A NEW MASTER CYLINDER, I HAVE A PROBLEM WITH THE ADJUSTMENT ON THE ROD? i HAVE "NEVER" HAD TO ADJUST ONE BEFORE, (NEW OUT OF THE BOXl AS THESE ARE SPECIFIC FOR YOUR MODEL, AND THERE IS NO DRAG ON THE TRUCK WHEN ROLLING IN NEUTRAL? AND HAVE WHAT FEELS LIKE SOME PEDAL, BEFORE YOU FEEL PRESSURE ON THE BRAKE PEDAL?
