2003 4.0litre intermittent/slow start issues
Old May 12, 2025 | 05:45 PM
Felix C's Avatar
Felix C
4th Gear
Hello Everyone,
Little help please.
186,000 miles. Original owner. Regular maintenance.
Previous month or so vehicle has lost its usually quick cold startup. Seemed to hesitate. Later in the day after use it is normal again.
Battery was a right at recommended replacement date.
Now has AC delco 850CCA. Cold Starts better and still not with the same zip as previous.
Alternator check is fine. No visible frayed cables/connectors.
Checked ect sensor and primed pump in case of that. No change.
Any thoughts?
Vehicle is very well maintained since 2010.
Thanks in advance.
Old May 12, 2025 | 05:47 PM
85e150's Avatar
85e150
Is this an F150? Shouldn't that be a 4.2 if so?
Old May 12, 2025 | 05:49 PM
Felix C's Avatar
Felix C
4th Gear
2003 Ford Explorer Sport. Did not see the appropriate category. Engine issue so thought identical in truck.
Looks like a Sport Trac with enclosed rear
Old May 12, 2025 | 06:05 PM
85e150's Avatar
85e150
So is it a slow crank, or an extended crank with no fire till it spins for a while?
My BIL had an early Explorer. Slow cranking was linked to battery cables that looked ok until you peeled back the insulation and found them corroded inside the insulation pretty much the full length of the cable.
Old May 12, 2025 | 06:09 PM
Felix C's Avatar
Felix C
4th Gear
With the new 850cc battery it starts on first turn and still does not have the Zip that was present more than few months ago.
Before I replaced the battery, it would hesitate then engine on.
these are both cold starts.
It would never have extended crank.
In both instances it starts/started normal later in the day after use. Engine warm.
pardon it has been in the shop three times now.
Wife's car and she is very attached to it.
Mint condition.
So you see I am on a mission from on high.
Old May 13, 2025 | 05:02 PM
aquanaut20's Avatar
aquanaut20
Perform a voltage drop test on starter circuit, then an amp draw on starter.. post results
Old May 13, 2025 | 06:32 PM
Felix C's Avatar
Felix C
4th Gear
Thanks. Will do.
Appreciate it.
Old May 13, 2025 | 06:55 PM
Johnny Paycheck's Avatar
Johnny Paycheck
What’s fuel pressure looking like? If unknown, find out.
Old May 14, 2025 | 01:05 PM
shorod's Avatar
shorod
After reading the posts above I'm still unclear whether the concern is (1) the speed at which the starter motor spins the engine over or whether the concern is that (2) the starter motor has to spin the engine over for longer than you're used to.
If (1), then the voltage drop and current draw tests would be useful information to help provide more information.
If (2), then knowing the voltage drop is still useful, but also knowing the fuel pressure reading (measured) would be useful. Also, what is the condition of the engine oil, has it been replaced recently, and what viscosity of oil was used? Did the new oil filter have an anti-backflow valve?
-Rod
20036.0Harrison
Nov 29, 2016 10:25 AM
Akblack10
Dec 3, 2011 07:45 PM
driximus
40
Dec 27, 2010 11:53 AM
mh5500
Aug 11, 2009 02:44 PM
Dingo128
Feb 23, 2004 06:09 PM
