View Poll Results: Please select your GPR or GPCM.
GPR - No Cold Start Issues.
71
80.68%
CPCM - No Cold Start Issues
12.50%
GPR - Having Cold start Issues
5.68%
GPCM - Having Cold Start Issues
1.14%
Voters: 88. You may not vote on this poll
Cold start Survey
Old Nov 24, 2010 | 11:53 AM
driximus's Avatar
driximus
Cold start Survey
I have been reading a lot of cold start issues, One thing I have noticed is that it seems to be on 7.3's with a GPR.
Starting a survey here to get an idea if this seems to be accurate. Please post the temp you started your truck at.
Old Nov 24, 2010 | 12:01 PM
just another truck's Avatar
just another truck
I will have issues, I do every year, I always need to go in and clean my connections at the battery, at least twice a year. But as of 22* so far this year, not yet.
Old Nov 24, 2010 | 12:04 PM
woodnthings's Avatar
woodnthings
I am still on the OEM Motorcraft batteries that were installed in '02. I have yet to have any cold start issues.......as long as I take the tuner off of No-Start before I try.
Old Nov 24, 2010 | 12:05 PM
Ponyboychris's Avatar
Ponyboychris
Truck is almost 9 years old, replaced GP's this fall and new GPR (Stancor) last spring. No cold start issues anymore.
And add to the mix, 5w-40 Synth oil and squeaky clean battery terminals...
Old Nov 24, 2010 | 12:13 PM
driximus's Avatar
driximus
Trying to figure out if the GPCM is less finicky then the the GPR. I have the GPCM and have had no issues down 12 degrees F
Old Nov 24, 2010 | 04:55 PM
brian42's Avatar
brian42
Veteran: Navy
206K+ and I'm still on the original glow plugs (and GPCM).
Old Nov 24, 2010 | 05:03 PM
clem1226's Avatar
clem1226
all original cold start equipment, 310,765 miles, lit off at -7 this morning.....the Rotella T6 has made a vast improvement how it sounds vs the Delo but it has always started on all 8 with both oils. wasn't plugged in this morning...opps.
Old Nov 24, 2010 | 05:18 PM
farmb0y's Avatar
farmb0y
I've replace all my glow plugs and the relay. That helped quite a bit, but switching to synthetic was probably the biggest thing to help get the old girl started. Now it starts up and purrs, compared to some romping and sputtering and smoking.
Old Nov 24, 2010 | 05:30 PM
malodin's Avatar
malodin
my trucks p.o. used starting fluid all the damn time so all my glow plugs barely work(i have not tested which ones are dead and what not), my gpr died so i switched it with my aih relay for the time being and seems to be working, still hates to start when its cold.
Old Nov 24, 2010 | 07:24 PM
RFD_Truckie's Avatar
RFD_Truckie
My GPR just died, and my truck doesnt like to fire if its much cooler than 40 degrees.
Switch with AIH relay,... ??? just dont use the relay for AIH or do you add the GP wire to that relay?
Thanks
Old Nov 24, 2010 | 07:31 PM
Waltdog's Avatar
Waltdog
of American machinists
No problems for me. Stancor GPR and brand new Megatrons last fall. It was -5 last night and my truck started fine this AM, It was however plugged in all night
Old Nov 24, 2010 | 08:13 PM
KH85's Avatar
KH85
Stock GPR as far as I can tell and prob stock plugs too. Started fine today after 11* last nite and not pluged in.
Old Nov 24, 2010 | 08:44 PM
racincowboy's Avatar
racincowboy
Mine started just fine this morning not plugged in and it was 15* out this morning. Not near as cold as Bend but pretty cool for this side of the hill.
Old Nov 24, 2010 | 08:47 PM
malodin's Avatar
malodin
i just unbolted the lead going to the glowplugs and bolted it to the outlet on the aih relay and swapped the 2 small wires onto the aih relay(i have an aih delete on it so it wasnt being used anyway)
Old Nov 25, 2010 | 01:09 AM
MauleOne's Avatar
MauleOne
Thumbs up Cold Start
Stancor GPR, T6 oil, clean battery terminals. Parked outside.
20 below and plugged in and it started like it was summer out.
1999 E350, 165K miles.
