same ign switch
Old Jun 14, 2024 | 08:04 PM
dremtofford's Avatar
dremtofford
same ign switch
for an 88 f150 tilt or non tilt. my ign switch fell apart so i put a new one in but, it will either be on all the way or start can't get both yet. and the truck is 40 miles away. also the button on the bottom of the column I push to get the key to lock broke on me.
Old Jun 15, 2024 | 08:22 AM
jas88's Avatar
jas88
I believe they are the same part.
Old Jun 15, 2024 | 08:43 AM
manicmechanic007's Avatar
manicmechanic007
Well, you are in for some column repair for the broken key release lever (first)
Then while you are in there you can check your ignition switch actuator
Good luck, have fun
Those switches used to come pinned in run IIRR
So run is right next to the spring loaded start section in the switch
Set the switch there (in run) and the key there (in run) then install the switch and test the operation
Old Jun 15, 2024 | 12:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
switch is the same for both tilt and non tilt. alignment is the key here. to get both accessory and start is has to be adjusted just rite.
Old Jun 29, 2024 | 10:23 PM
dremtofford
i will tinker with it when the doctor says it is ok to work on stuff—stupid bypass surgery.
Old Jun 30, 2024 | 04:38 AM
manicmechanic007
Good luck
You will be back at it shortly
Do they have you doing any cardio rehab exercise stuff?
Old Jun 30, 2024 | 08:19 AM
dremtofford
Same ogn switch
Yep tred miill exercise bikes star steps.8
rhol55
Sep 21, 2016 08:01 AM
hawgystyle
Oct 14, 2010 05:29 AM
70torino429
Jul 14, 2010 11:54 AM
Point Blank
Aug 18, 2009 06:57 AM
kill_them_all
Electrical Systems/Wiring
Dec 22, 2004 10:14 PM
