Transmission confusion
Old Apr 20, 2024 | 04:09 PM
IMColor's Avatar
IMColor
4wd Low
I have a '98 super duty cutaway box truck. Trying to identify the transmission in it and I'm getting mixed messages from various threads. One thread said that the 98 V10 only came with a 4R100, and another thread said that the 4R100 has a speed sensor on top of it. My transmission doesn't have a speed sensor on the top. The tag reads:
F8UP-JA
PRB-S
00000267
BD-8A07
The transmission is slipping and I need to rebuild it, but I need to make sure I get the right kit. Any help would be appreciated.
Old Apr 20, 2024 | 08:55 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The 4R100 is a renamed E4OD. They are really the same transmission.
In 1998 the Superduty was launched and the name changed from E4OD to 4R100. But the early '99 trucks (built before June 1999) had transmissions that were called 4R100, but did not have the 4R100 speed sensors and really were E4ODs. There is probably no difference in the kits between an E4OD and 4R100 rebuild kit.
Old Apr 21, 2024 | 02:34 PM
IMColor's Avatar
IMColor
4wd Low
Thanks for the input, seems to make sense. That said, the below link states that the 4R100 had heavier duty internals:
​​​​https://rdipower.com/truck-transmiss...e40d-vs-4r100/
If that article is true, it seems there would be a difference in the kits.
Old Apr 21, 2024 | 03:13 PM
Mark Kovalsky
The hard parts are heavier duty in the 4R100, but hard parts are not part of a rebuild kit.
Old Apr 21, 2024 | 06:03 PM
IMColor's Avatar
IMColor
4wd Low
Got it. Much appreciated guys.
Old Apr 27, 2024 | 05:36 PM
IMColor's Avatar
IMColor
4wd Low
Well, I got a rebuild kit for a 4R100 and it's not the right kit. This transmission has a cast coast drum with 64 teeth and the kit came with clutches and steels for a 32 teeth stamped steel drum. The overdrive clutches and steels are also different.
That said, it appears to be a 98 E4OD?
Pj Gillispie
Nov 22, 2016 03:51 PM
Cactus Jack
Jul 18, 2012 02:30 AM
PeechyGA
1983 - 2012 Ranger & B-Series
Aug 9, 2006 05:53 AM
fordbabe0014
Nov 30, 2005 06:21 PM
