Sponsored by: Real Truck
4r100 issue please help
Old Nov 19, 2016 | 01:12 AM
Pj Gillispie's Avatar
Pj Gillispie
hey there everyone I recently bought a 1999 f250 super duty with a v10 and 4x4 this is my first truck so I don't know too much about them but The truck needs a new transmission so I went out and got a 4r100 from a 2001 f250 v10 4x4 the issue that I'm confused about is when I got the two transmissions side by side I realized the new transmission that I got for the truck has the two connections on the top of it for the output speed sensor and the turbine speed sensor but my original transmission does not have these connections. I'm not sure if I can still use this new transmission I got or will it not work? Thanks in advance
Old Nov 19, 2016 | 06:47 AM
Tom's Avatar
Tom
I think there were some changes from '99-'00, and I don't think they are compatible. @Mark Kovalsky would probably have a better answer for you.
Old Nov 19, 2016 | 07:13 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The good news is that those two connections on top can safely be ignored. Just leave the sensors in place to plug the holes. The bad news is that you are going to have to swap the solenoid bodies (located in the pan) and either swap the pump or modify the pump you have.
Jeg's has instructions on how to do this. CLICK HERE, then go towards the bottom of the page and click on INSTRUCTIONS. Download the file. You don't have to buy the kit, but it might be easier to do that.
Old Nov 19, 2016 | 07:39 AM
Pj Gillispie
Sounds good I will look into doing that you're a life saver thank you very much
Old Nov 19, 2016 | 07:51 AM
Pj Gillispie
If I was to swap the pumps do you mean just take the one out of the old transmission and put it in the new or buy a different pump? I've never opened a Trans before besides changing the filter and oil to be honest lol
Old Nov 19, 2016 | 07:56 AM
Mark Kovalsky
Yes, that's what I mean. But if the old pump is damaged or worn, you don't want to use it. What's wrong with the original trans?
Old Nov 19, 2016 | 08:14 AM
Pj Gillispie
The original Trans doesn't have drive and only will go in reverse If I rev the Rpms up a decent bit but it would only creep a tiny bit when I did that
Old Nov 19, 2016 | 09:06 AM
Mark Kovalsky
Don't use that pump. It might have been the cause of the failure.
Old Nov 19, 2016 | 09:10 AM
Pj Gillispie
Ok sounds good thank you very much
Old Nov 22, 2016 | 03:25 PM
Pj Gillispie
hey mark I got a question about the pumps could it be possible that they are the same because I was looking at them both and they are both labeled as RF-F81P-7A105-AA
is there a way I can tell if they are the same without pulling them? I called my local shop and they was 200$ just to look at them lol
Old Nov 22, 2016 | 03:51 PM
Mark Kovalsky
Those are casting numbers. That doesn't mean they are the same. Use the instructions I linked in post #3 and see if the orifice is 0.250" or about 0.030".
wicker63
Oct 24, 2016 06:54 PM
skyfox10
Mar 8, 2014 04:38 PM
Civictos2000
General Diesel Discussion
Mar 28, 2012 01:22 PM
crazyboutford44
Jun 6, 2010 11:32 PM
afbrian13
Nebraska Chapter
Sep 21, 2007 12:57 PM
