How do I know?
Old Mar 2, 2024 | 09:16 PM
tradosaurus's Avatar
tradosaurus
How do I know?
5 years ago I had my emissions deleted and s as CP4 kit installed.
For sheets and grins I looked to see the kit installed but not sure what I’m looking at.
now I’m wondering if it was installed
Old Mar 3, 2024 | 07:22 AM
scraprat's Avatar
scraprat
Top Answer: 5
If you had the prevention kit installed you would see extra hoses and an extra filter in the engine bay. Plus after 5 years maybe the added prevention filter should of been changed.
Old Mar 3, 2024 | 08:09 AM
tradosaurus
looking at my invoice what is a fuel prevention plate?
Old Mar 3, 2024 | 08:23 AM
scraprat's Avatar
scraprat
Top Answer: 5
Do you have anothe filter mounted on the fire wall area behind the coolant tank?
Something like this...
Old Mar 3, 2024 | 08:35 AM
tradosaurus
No.
Old Mar 3, 2024 | 09:39 AM
tradosaurus
I’ll call the place on Monday and ask about that part of the invoice
Old Mar 3, 2024 | 09:42 AM
scraprat's Avatar
scraprat
Top Answer: 5
Unless they put something like this on?
https://whitesdieselperformance.com/...revention-kit/
Old Mar 3, 2024 | 09:49 AM
tradosaurus
you might be right but I can’t see those parts
Old Mar 3, 2024 | 09:55 AM
speakerfritz's Avatar
speakerfritz
The return filter is part of the gen2 kit which came out about 3 years ago.
if you have a DPK installed 5 years ago it was a gen 1 kit.
Old Mar 3, 2024 | 10:07 AM
speakerfritz
It will be hard to tell with everything installed.
there will be a hose coming from a plate under the metering valve.
i think the lower half intake will block your view.
Old Mar 3, 2024 | 11:46 AM
97-psd's Avatar
97-psd
I think 5 years is a long time to ask them to remember.
what has recently caused you to wonder about it? They might have better luck if you took the truck and asked them to show where those parts are installed so you can better familiarize yourself with them.
Old Mar 3, 2024 | 12:00 PM
Overkill2's Avatar
Overkill2
That White's Diesel Performance link posted looks like the widely copied first gen of S&S's kit which was too short a run of hose, as the metallic particles back fed and contaminated the system anyways...
Looks like you need the genuine article, S&S's Gen 2.1 kit with the Donaldson filter to catch all the crap when the pump goes and it flows through the return line back to the tank.
Old Mar 3, 2024 | 12:52 PM
tradosaurus
S&S cp4
i could see a plate with an S on it so I believe this one is it.
so how easy would it be to adapt to the newest kit?
Newest kit
Old Mar 3, 2024 | 01:46 PM
Overkill2's Avatar
Overkill2
Originally Posted by tradosaurus
S&S cp4
Newest kit
I'd reach out to S&S and see if you could upgrade with what you have...
When they came out with the Gen 2 kit, originally with the SNAPP filter, they extended the line out to 25 inches and tee it off...This is the Gen 2.1 update because the company Parker Racor (or Racor Parker ??) couldn't keep up with the demand so S&S went with a spin on filter set up.
The return filter/head with hoses can be purchased for $160... but I don't know exactly what you have and I'm not sure the original Gen 1 kit they designed will work with just the return head/filter/hoses or if you would have to buy the whole kit for $400.
Take some more pics of the plate and hose...
Old Mar 3, 2024 | 02:27 PM
kayakingpoodle's Avatar
kayakingpoodle
S&S offers an upgrade option for the 1st gen systems it is in the drop down menu.
From the page : "For those looking to improve the debris management of their first-generation Disaster Prevention Kit, the S&S Gen2.1 Fuel Return Filter Assembly (#CP4-6.7F-BP-G2.1-RFA) can be purchased separately for $160.00 USD."
This kit "should" work on the copies of the early kit too.
It is also very easy to install even if you are not mechanically inclined. If you can change the fuel filter in the engine bay you should have no problems installing this filter.
