Flathead Install
Old Jul 8, 2022 | 07:10 PM
philbillee's Avatar
philbillee
New Member
Flathead Install
We are new to the Flathead World.. Our question is ,We are putting a C4 Automatic behind our 1952 Flathead and we bought the Speedway Motors Kit to adapt it to the engine and needed to find out if we can attach the transmission to the block and put it in all at one time. An Old Timer told us it would crack the block thanks
Old Jul 9, 2022 | 01:25 PM
LT150's Avatar
LT150
4th Gear
will be fine, it's the older 59AB blocks that break easy. Your block should have 7/16" NC cap screws at least four to hold adapter on to engine. Laurie
Old Jul 10, 2022 | 12:03 PM
f5fordgirl's Avatar
f5fordgirl
Engine and trans can be slipped in as one, flatheads are heavy, make sure you have good mounting points to lift it with, a good chain, and an engine leveler helps too.
Fred Tate
New Member Introductions
Jan 13, 2016 06:37 PM
Wonderingluke19351
Jul 16, 2015 05:28 PM
F350-6
22
Feb 8, 2009 06:54 AM
