Oil Change and Oil Pressure on 8BA Flathead
Old May 19, 2022 | 10:06 AM
shadderszxr's Avatar
shadderszxr
Hi All,
Time for some dumb questions....
What oil is everyone using 20/50 etc, I've seen various comments across the web (as the manual is not using multigrades) and some recommend thicker oils to help with oil pressure?
I've topped mine up slightly (very little new oil) and seen that the oil pressure gauge now doesn't run continuously in the middle where is was previous...It is always low at idle and picks up on the run, but now only moves when you rev the motor. I've seen some people get into arguments at this point over flow and pressure saying as long as you have flow, ignore the pressure gauge etc!
Also can I check that the filler/breather tube is the best point for filling the engine with oil..??. (I told you there was going to be dumb questions)
Old May 19, 2022 | 11:10 AM
mtflat's Avatar
mtflat
You'll get all those same opinions here that you found online.
20/50 acts like 20 wt when cold and like 50 wt when hot.
Running straight 30 or 40 wt is a middle of the road approach.
All are fine in the engine... guys try different oil viscosity according to how much the truck leaks on the driveway/shop floor.
Not sure what you mean about the breather/oil fill tube question. It's the only place you can add oil to the engine.
Old May 19, 2022 | 11:36 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
There are many opinions/thoughts, but I run straight 30 with a ZDDP additive in my flatheads and have been happy and I feel it matches up pretty well with the manufacturers intentions. My pressure starts at just a hair above 30, and drops a wee bit as it warms - as expected.
Old May 19, 2022 | 12:20 PM
shadderszxr
I saw on another forum who were talking about filling them from the rear (I think it was a mid 40s flathead) and that was just a breather but the guy had a newer intake manifold which didn’t help the conversation.
It just made me question, was I doing right lol. I know I can trust people on here, I’ve never been let down yet!
Old May 19, 2022 | 01:01 PM
mtflat's Avatar
mtflat
Got it! Yep the 40's oil cap was combined with the fuel pump stand at the back of the engine. The change in the late model flatheads also rerouted the crankcase ventilation. Swapping parts early/late can cause other issues that need to be solved.
Old May 20, 2022 | 12:04 AM
Bob Ingram's Avatar
Bob Ingram
Following…
In my EAB I’ve been running 20/50. I installed a mechanical gauge and I see pressure in the range of 30-40Lbs cold. When it warms up, the idle pressure is very low, 5lbs or so, but goes up at speed. I’ve been told to expect 10lbs per 1000RPM, so at idle (500 RPM) 5lbs is ok. I don’t have a tach but at 55mph I get about 40lbs so I think that may be ok.
I too am interested in what folks have to say.
Old May 20, 2022 | 12:57 AM
shadderszxr
Originally Posted by Bob Ingram
Following…
mine did all of this until I topped the oil up slightly. Now it sits at the bottom of the gauge, not at zero so maybe 5. But it is at 30-40 when you start it then it slowly drops.
Old May 21, 2022 | 12:53 PM
shadderszxr
Ok, update…. I’ve changed the oil filter, replaced the seals, and made a gasket for the belly pan ( just the round one). Pulled the oil pickup basket and checked it. All clean, a little sludge in the bottom of the belly pan, but not much at all. ….
put new 20/50 classic car oil in and ran it for a few seconds. No problems, leaks or noises. Checked the dip stick and kept topping up until right.
now running continuously at 30 on the pressure gauge no matter what speed or revs!! Happy camper again 😁
Old May 21, 2022 | 01:02 PM
abe's Avatar
abe
That's good. Lucky you have a real oil pressure gauge. In 1954 F-100's got an idiot light for oil pressure as well as an idiot light for the generator charging. F-250 and up still had gauges.
Old May 21, 2022 | 04:43 PM
Bob Ingram's Avatar
Bob Ingram
https://hosting.photobucket.com/images/yy255/shadderszxr/1E1DC93E-2843-4FD4-B102-BE833E0DDA.jpeg?width=960&height=720&fit=bounds
I hate to be a doubter, but when I change my oil I get the same results, for about 100 miles, then it goes back to the earlier behavior, lower pressure at idle after warmup. I don’t think it’s a concern because as soon as the RPMs increase the pressure goes back up.
Now if I’m wrong, I’ll eat my words. Either way, your engine sounds healthy.
Old May 22, 2022 | 07:22 AM
Bimmerboy1989's Avatar
Bimmerboy1989
We run Amsoil 10-40 Z-Rod in both our ‘48 with a 460 and 49 with a flathead I6. You should choose your oil’s viscosity based on the ambient temperatures you expect to drive in. We chose 10-40, because it can operate in a temperature range of 5F to 122F. Oil pressure should climb with RPM generally.
MHBronc93
1978 - 1996 Big Bronco
Jun 8, 2018 11:27 AM
NorthEastTexasHog
Dec 18, 2015 01:07 AM
xtrford
Oil & Lubrication
Nov 5, 2005 02:47 PM
highboy73
Feb 2, 2005 08:24 AM
barebackjake
Oct 24, 2004 12:18 PM
