88 5.0 oil pressure issues - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Bronco > 1978 - 1996 Big Bronco
Reload this Page >
Old 06-05-2018, 07:52 AM
MHBronc93
MHBronc93 is offline
MHBronc93 is starting off with a positive reputation.
Recently I seem to lose oil pressure when the engine has warmed up and I'm either slowing down or stopped completely. I have the oil pressure switch I just need to install it. Also the oil is old and I need to change it. Could changing those solve my issues or is it something bigger?
Old 06-05-2018, 10:32 PM
g_k50
g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
My 1990 5.0L Bronco loves the straight 30W oil, the lighter oil seems to burn off quicker than the 30W. While not losing any of the power from using a higher 40W oil.
Old 06-06-2018, 10:18 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
You know the oil is old, change it. If you are still concerned about oil pressure put a real oil pressure gauge on.
Old 06-06-2018, 02:17 PM
AbandonedBronco's Avatar
AbandonedBronco
AbandonedBronco is offline
AbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to allAbandonedBronco is a name known to all
My '85 (EFI) 302 has the same issue going on. Oil pressure is just fine while driving, but after it's warmed up, and I'm stopped, it drops to 0.
I've changed the oil and filter, tuned it up, etc, but it doesn't seem to make any difference.
I do wonder if it just has really sensitive gauges / oil sender or something since even when it reads 0, it idles smooth and there's no noise. If there really was 0 oil pressure, there'd be some sound coming from the engine, like lifters clacking or something.
Granted, you definitely want to do your diagnostics since you don't want to just convince yourself it's okay, and then have it burn up. A real oil pressure gauge would be a good start.
Old 06-08-2018, 12:58 AM
g_k50
g_k50 is offline
Any engine is going to have lower oil pressure after it warms up. It has to do with the mechanics of materials, the steel gets warmer and it expands, Holes get larger than journals do, so your crank journal clearance and your rod bearing clearances get larger and the oil has a easier time flowing out of those areas. Additionally the oil viscosity gets lower so the fluid oil moves thru tight spots easier, all these add up to decreased oil pressure on the gauge,
One solution is to use a higher viscosity oil to begin with. A search for oil nomenclature will give you the details on oil viscosity and the oil labels.
Old 06-08-2018, 12:27 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
only use a motorcraft, wix or purolator oil filters. 10w40 oil of your choice . I like using Delo 15w40 diesel oil. the high zinc content is great for the motor and the oil does a great job of keeping the motor clean between changes.
Fixnstuff
09-26-2016 10:56 PM
rolley76
13
03-15-2016 10:55 AM
Derrick Moore
08-20-2011 01:21 PM
websthes
General Automotive Discussion
13
09-29-2007 01:27 AM
yama916
1968-2013 Full Size Vans
11-27-2005 03:00 PM
Quick Reply: 88 5.0 oil pressure issues
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
