rear running lights not working. brake light and signals work
hey guys. my rear running lights on both sides stopped working. i’m struggling real hard on finding the problem
brake lights and signals work just fine, i was washing my truck and they stopped. i check all fused and looked for any broken wires i found nothing. at the rear of the truck i checked the plugs no power going to them and help would be much appreciated.
It is only the rear parking lights not working? I'd so then a corroded connector or broken wire is your best bet. There are two connectors at the very end of the driver side frame rail one is for trailer lights one is for tail lights. I would start at the tail light connector there checking for corroded pins and damaged wires. Should be the brown wire for rear parking lights. If all is good there the next junction is the inner fender on the driver side back by the firewall. It will be one of the three large square connectors.
