CAC Boots
Old Feb 15, 2022 | 02:02 PM
SNIPER168308's Avatar
SNIPER168308
CAC Boots
Hey fella’s, my ‘00 7.3 has 340k on the clock. I’ve completed a few of the minor mods mentioned here, but nothing related to major power increases. Due to the trucks age, I’m concerned the CAC boots might be nearing replacement (they are stock). None have any holes I can find, but there’s some oil on the bottom of ya run your fingers across them.
I was going to pressurize the system and look for leaks. I built a “plug” with an air hose connection to put in the intake tubing. But, the only problem I see is it will not pressurize the turbo, tubes, intercooler, etc because it bleeds air into the crankcase via the tube that attaches to the drivers side valve cover. How are you all stopping air loss there during pressurizing the system.
and, what’s your suggestions on CAC boot replacement? Is there specific times to replace, or other reasons besides the obvious hole / leak?
Thanks,
Clay
Old Feb 15, 2022 | 02:30 PM
CousinCarl's Avatar
CousinCarl
You have to hook your boost leak detector to turbo down stream from ccv.
I like RiffRaff's boots. Double the silicone thickness. American vendor. Supporter and member of FTE.
Old Feb 15, 2022 | 06:55 PM
ESwift's Avatar
ESwift
CNCFAB
Old Feb 15, 2022 | 08:24 PM
RacinJasonWV's Avatar
RacinJasonWV
Cousin Carl is correct. Move the boost leak detector closer to the turbo. You don’t want to pressurize the crankcase. It’s hard on seals.
Old Feb 15, 2022 | 09:50 PM
RigCity's Avatar
RigCity
With 340 k I would replace the boots and clamps. I have riff raff and Mishimoto boots both great products. Additionally you might as well buy the riff raff plenum inserts they really help a ton!!! Better to replace a tired part than run it until there’s problem. Definitely worth doing a boost leak test though if you want to confirm/ check the system. Seems the stock boots become hard and brittle with age thus not sealing as well.
Old Feb 16, 2022 | 08:32 AM
FordTruckNoob's Avatar
FordTruckNoob
Another vote for RiffRaff boots. Get the clamps to go with those too. I think RiffRaff sells all of it as a set to save you the trouble of mixing and matching.
djmechanic
Feb 28, 2016 07:25 AM
DDPJ
Oct 1, 2015 10:56 PM
tgarrisoniv
Mar 29, 2012 02:20 PM
dwrestle
Nov 18, 2011 12:20 AM
live2hunt
Aug 16, 2005 08:22 PM
