Water Leaking into Cab
Old Jan 20, 2022 | 01:20 PM
Strand10's Avatar
Strand10
FTE,
1962 F100 Unibody.
New door seals 18 months ago.
Water is running from gutter above driver door, down the seal, and onto step. It pools in the front of the step due to truck sitting slightly nose low. As soon as I open the door, water pours out.
Any thoughts?
Old Jan 20, 2022 | 01:37 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
These trucks do not have the tighter tolerances that newer vehicles do. Has the cab settled? Are your doors aligned as best they can be? If you realign them now, the door seals, by now settled in, may need to be changed again. Is that channel rusted through?
Old Jan 21, 2022 | 05:05 AM
AZSCAWPION's Avatar
AZSCAWPION
How are your window sweeps? Even if new they wont keep water out of the door. Any water/snow collected on the glass will drain through the inside of the door cavity and can puddle on the step.
Old Jan 21, 2022 | 05:22 AM
Strand10's Avatar
Strand10
Sweeps are new. I can see the water marks running from the back channel to the front of the step well.
Old Jan 21, 2022 | 05:25 AM
Strand10's Avatar
Strand10
Entered in error. Disregard.
Old Jan 21, 2022 | 05:28 AM
Strand10's Avatar
Strand10
No settling I can see and channel isn’t rusted through. Door is in good alignment (the passenger door isn’t and it doesn’t leak!). Might get a new seal for the driver side and reposition it slightly. Also might put a small rudder, triangular dam on the door frame to keep the water from flowing into the foot well.
Old Jan 21, 2022 | 08:12 AM
lizardman1's Avatar
lizardman1
Clean the area above the door and use clear silicone to seal that gap, assuming that is the source.
CDeWitt07
Jan 23, 2020 07:09 AM
HTM101
Jun 25, 2019 04:58 PM
Db966
2015 - 2020 F150
Oct 8, 2018 07:42 PM
air1jpg
2004 - 2008 F150
May 2, 2010 05:45 PM
fords_forlife
Paint & Bodywork
Jul 30, 2005 11:17 AM
