CCV Reroute
Old Sep 15, 2021 | 10:00 AM
Kevin Heston's Avatar
Kevin Heston
CCV Reroute
2011 F250 6.7 200k. put a ccv reroute on the truck a few months ago and everything seems to be just fine. I've heard to put it back to stock but idk if a reroute kit is actually better.
Old Sep 15, 2021 | 12:07 PM
Pugga's Avatar
Pugga
So... what's the problem. A CCV reroute won't hurt anything, assuming you didn't route it to the exhaust (which apparently some people do). If its not causing issues, no reason to go back to stock. Who told you to go back to stock and why?
Old Sep 15, 2021 | 12:13 PM
Kevin Heston
I've heard from a lot of people that it will make the turbo seals fail. Which is odd because the truck always has white smoke come out of the tail pipe when i give it about half or more throttle.
Old Sep 15, 2021 | 12:56 PM
Pugga's Avatar
Pugga
You're opening Pandora's box there... The theory is, by rerouting the crank case vent to the atmosphere, it is no longer under a vacuum and the case can build pressure faster than it normally would. This is how, again in theory, you get a turbo seal failure. Stock truck, stock loads, I highly doubt you'll have a problem, but that's just me and I'm not a mechanic by any means. Maybe someone who knows the science behind all this can comment.
I didn't want oil in the intake, I also live in a state that has pretty strict inspections so I went with the Mishimoto catch can kit that grabs the oil then feeds the air into the stock CCV filter. That might be a viable option for you depending on what your goals are.
Old Sep 15, 2021 | 02:54 PM
Overkill2's Avatar
Overkill2
Another option is to run a Mishimoto oil catch can to keep all the crap out of the intake.
Old Sep 15, 2021 | 04:04 PM
Kevin Heston
I will definitely look into that. The turbos on these things aren't good anyway in terms of longevity.
Old Sep 15, 2021 | 05:10 PM
Overkill2's Avatar
Overkill2
https://www.mishimoto.com/ford-6-7-p...2011-2016.html
Not sure of your year truck but here's a link.
Old Sep 16, 2021 | 08:17 AM
Kevin Heston
It's a 2011 so I'm good. Appreciate it.
jimzpsd
Feb 9, 2019 12:01 PM
Bvill01
Jul 11, 2012 07:47 AM
Jayybird
Jun 7, 2010 09:50 PM
Ehammond
20
Aug 13, 2007 01:20 AM
ztodd377
27
Mar 27, 2007 04:07 PM
