"In tank" Mod Kit
Old Aug 6, 2007 | 06:26 PM
Ehammond's Avatar
Ehammond
"In tank" Mod Kit
Getting time to do the "In Tank" mod. Who has the best Mod Kit for doing this?
Old Aug 6, 2007 | 06:47 PM
John311t's Avatar
John311t
I belive ITP has a good one.
Old Aug 6, 2007 | 07:23 PM
F250_'s Avatar
F250_
I have the ITP kit installed, and it is easy to do. There is another kit available from someone else, can't remember whose, but I didn't like the way the return line was routed and the mix box kept by using that particular kit. The ITP kit seems to have a better approach, in my opinion.
Here's the link to ITP >> http://www.itpdiesel.com/store.php?c...on=show_detail
Old Aug 6, 2007 | 07:26 PM
Mach1's Avatar
Mach1
ITP kits is tough to beat, however the filter has to be changed regularly. However your stock fuel filter will last longer.
Old Aug 6, 2007 | 07:33 PM
Ehammond's Avatar
Ehammond
I noticed ITP kit is 5/8 inch. Is this the size of the line in the tank that it attaches to?
Old Aug 6, 2007 | 07:42 PM
elvia's Avatar
elvia
I just installed mine last week. the kit tubing was the same size as existing tubing. the fuel line is 3/8", not 5/8"
Old Aug 6, 2007 | 07:48 PM
RAMPAGE_F350's Avatar
RAMPAGE_F350
The ITP kit with the Baldwin filter should have 3/8 inch lines . However, Dennis does sell a 5/8 inch pick-up kit.
Old Aug 6, 2007 | 08:12 PM
Ehammond's Avatar
Ehammond
That's what I saw on the website.
Old Aug 6, 2007 | 08:52 PM
indebt's Avatar
indebt
how often are you all changing that baldwin filter?
Old Aug 6, 2007 | 08:53 PM
Ed in Maine's Avatar
Ed in Maine
So the kit linked above at ITP is a passive filter with no electric pump integrated in. Wouldn't that make your stock electric pump work even harder?
I am looking into a pre pump filter, but I thought they all had some type of pump integrated in?
Old Aug 6, 2007 | 09:16 PM
aklim's Avatar
aklim
You bet it will. However, the fact that you are gutting the filters at the tank when you do this makes up for it
Old Aug 7, 2007 | 05:43 AM
R.E.M's Avatar
R.E.M
has anybody put the kit in without the filter? I see you can buy it with or without the filter
Old Aug 7, 2007 | 05:55 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
I installed mine before Dennis had the option with a filter. I installed a very large sub-micronic filter before a lift pump anyway.
Old Aug 7, 2007 | 07:01 AM
Kwikkordead's Avatar
Kwikkordead
Get the filter or you'll be buying a fuel pump later on due to the screen inside the inlet getting clogged. (personal experience)
Old Aug 7, 2007 | 07:04 AM
aklim's Avatar
aklim
That is only good if you want to install your own filter. Either way, you are removing the filters in the tank. Are you sure you want the crud in the tank going past your pump?
