Injectors - if replacing 1, do them all? 170k mi
Old Jul 21, 2020 | 10:20 AM
KC8QVO's Avatar
KC8QVO
Title says it all. If you were up against replacing an injector would it make more sense just to do all of them with as many miles are on the truck? 170k?
Old Jul 21, 2020 | 10:22 AM
speakerfritz's Avatar
speakerfritz
I would...no sense in creating 7 more seperate break fix events.
Old Jul 21, 2020 | 10:26 AM
Just Strokin's Avatar
Just Strokin
You will need to get the PCM updated with the new injector IQM code for any injector you replace.
Old Jul 21, 2020 | 10:31 AM
KC8QVO's Avatar
KC8QVO
Thanks Larry. I am aware of that.
Its at the dealer and I'm mulling this one over for them to do it instead. I don't have ForeScan set up here (yet)... Maybe I should dive in and do it myself, though. That's one thing I am wanting to nail down.
Old Jul 21, 2020 | 04:13 PM
dirthawg's Avatar
dirthawg
At $300 per injector I would replace one at a time. 6.7L injectors are not common failures even at high mileages. At the very most I would replace the injectors on the same bank as the failed injector since the labor to get to them is roughly the same as replacing one.
Old Jul 22, 2020 | 05:22 AM
kper05's Avatar
kper05
I had only my #5 injector replaced in early 2018. It has been fine. They can test each injector with IDS.
KC8QVO
6.7L Power Stroke Diesel
Nov 5, 2018 05:23 AM
johndeerefarmer
Jul 24, 2016 07:13 AM
JT250
Sep 11, 2012 01:42 PM
ltl_jrw
Jun 27, 2011 11:29 PM
